  • hobbyfun Friend
    #144618
    Dear all,
    sorry to submit this thread again, I just want to communicate my login details. If you can go to my site and try to add a new template, you will know what’s happend behind. and as well, the problem with upload image by using IE. Many thanks for your appreciable solution, I have been bothered by this problem since last week.
    Best regards.
    Hobbyrun:((
    Arvind Chauhan Moderator
    #318693
    Dear hobbyfun,
    I would be deleting your earlier thread. We could see your login info in that thread too.
    Please try again now. I have fixed the directory permission problems.
    Your hosting / Joomla installation has problems related with directory permission issues. Generally CHMOD of 755 should work fine. Had to set some of your directory permissions to 777 to make it work.
    Arvind
    #318695
    Its a Joomla Related problem. Did you search google for the error?
    Let me show you the results of Google search for this error >> http://tinyurl.com/ycbggrd
    Arvind
    hobbyfun Friend
    #318698
    Hi Arvind,
    Thank you very very much. The problem is resolved.
    By the way, have you tried to upload a image from my site, I still can’t do it under IE. Could you tell me what’s happend.
    #318699
    hobbyfun;146420Hi Arvind,
    No I did not try to upload images. It again must be related to the permission problems you have in your Joomla Installation. You are bound to face problems at almost each step, because of your permission problems and its not wise to CHMOD all the directories 777. High time you evaluate your hosting environment and change host if required.
    Can you attribute image uploading problem to the Template you are using? Please try the same by changing the template to Joomla default. If it works, then let us know.
    I am afraid we wont be able to help much with your Hosting / Joomla setup problems. Anything related to JA Templates, feel free.
    Arvind
    hobbyfun Friend
    #318701
    <em>@drarvindc 146421 wrote:</em><blockquote>No I did not try to upload images. It again must be related to the permission problems you have in your Joomla Installation. You are bound to face problems at almost each step, because of your permission problems and its not wise to CHMOD all the directories 777. High time you evaluate your hosting environment and change host if required.
    Arvind</blockquote>
    Hi Arvind,
    upload image works with firefox, but not with IE. I don’t know where is the problem. if you can help me with this issue. thank you
    #318702
    Moving this thread to General Forums. Non Template related issue.
    Arvind
    scotty Friend
    #318709
    hobbyfun;146423Hi Arvind,
    Disable all plugins, extensions and addons you have in IE and try again.
    hobbyfun Friend
    #318732
    <em>@scotty 146430 wrote:</em><blockquote>Disable all plugins, extensions and addons you have in IE and try again.</blockquote>
    Dear scotty,
    Can you tell me where to disable all these things. Thanks a lot.
This topic contains 9 replies, has 3 voices, and was last updated by  hobbyfun 15 years, 2 months ago.
