  • petertp08 Friend
    #127653
    When I try to install the Edenite v1.1 for Joomla 1.5.x I get the following error message:
    # JFTP::connect: Could not connect to host “http://www.s240075398.onlinehome.us” on port 21
    Any ideas what could be causing this???:-[
    petertp08 Friend
    #245827
    I manually uploaded the files and it seems to work now. However, if I try to change the parameters, Joomla gives me the same error message…..
    What is going on?
    #245838
    I think that is error of your network when connect your server,maybe port 21 have problem, plz contact with admin of your server
    zuesty Friend
    #245844
    I got similar error at first. Then, I unzipped the files and uploaded the folder and installed from directory. It works perfectly fine now.
This topic contains 4 replies, has 3 voices, and was last updated by  zuesty 16 years, 8 months ago.
