  • mfcphil Friend
    #140149
    Does anyone have a copy of the css code to add to the css folders that give us the Testimonial Quotes with the figure images included.
    4874
    This one is from the Ja Edenite template….can’t find the code in the css file
    You should be able to simply press testimonial style tpye in the styles option box and get this to work
    1. testimonial2
    ShannonN Friend
    #300877
    mfcphil;123752Does anyone have a copy of the css code to add to the css folders that give us the Testimonial Quotes with the figure images included.
    4874
    Using Firebug it shows that the testimonials box is a div called
    <div class=“moduletable_hilite”>
    containing
    <h3>Testimonials</h3>
    <blockquote class=”testimonial”>
    <span class=”open”>At</span>
    id ut nunc Nullam Quisque Lorem congue metus volutpat mauris.
    <span class=”close”>Nulla.</span>
    <span class=”author”>
    <a title=”Testimonial” target=”_blank” href=”http://www.joomlart.com”>J.Frank</a>
    </span>
    </blockquote>
    <blockquote class=”testimonial“>
    <span class=”open”>Lacinia</span>
    justo Donec porttitor Mauris vel risus velit neque Vestibulum
    <span class=”close”>fames</span>
    <a title=”Testimonial” target=”_blank” href=”http://www.joomlart.com”>F.Thomas</a>
    </span>
    </blockquote>
    justo Donec porttitor. Justo Donec
    </span>
    </blockquote>
    Css found in
    div.moduletable, div.moduletable_menu, div.moduletable_text, div.moduletable_hilite {template.css (line 647)
    margin:0;
    padding:0 10px 10px;
    Also in typo.css etc
    blockquote.testimonial {typo.css (line 35)
    border-bottom:1px solid #E7E8E6;
    padding:0 0 10px;
    blockquote {typo.css (line 21)
    padding:1em 40px 1em 15px;
    p, pre, blockquote, ul, ol, h1, h2, h3, h4, h5, h6 {template.css (line 90)
    margin:10px 0;
    padding:0;
    Is this what you wanted?
    Cheers ShannonN
    mfcphil Friend
    #300898
    Hi Shannon
    What I want to know is how to get this working.
    There is a testimonial style button in the editor for this template so if you choose that style the effect in the demo should be what we get on the page…its not
    So do we need to add some of the info you have shown to the css files or folders?
    mfcphil Friend
    #300902
    Shannon
    Got there in the end using the code you provided.
    Turned editor off and played about for a while
    <span class=”open”>Start your text here</span>
    middle part of your sentence
    <span class=”close”>finish it here.</span>
    </span>
    </blockquote>
    </span>
    </blockquote>
    </span>
    </blockquote>
    ShannonN Friend
    #300904
    mfcphil;123816Hi Shannon
    Shannon
    Hi Phil
    I haven’t actually used the template so was unaware of that button and it’s usage, I merely thought you requested the relevant css to match the panel etc, But in the end I’m glad the supplied code gave you some hints, all’s well that ends well.
    ShannonN
    ShannonN Friend
    #301037
    Hi Phil
    Given your later post and the need to turn off the feature etc. does this mean the testimonial button doesn’t work as planned , if so can you log a bug report with JA ? Best they add it to the list:) if it’s a bug?
    Shannon
    mfcphil Friend
    #301039
    Well the style button certainly did not work as planned…and you have to be careful where your putting your text when your editing or you start losing thing like the quotation marks or the little people figures.
    But your right as they have the Testimonial in the css file it should work….the testimonial in the css does not have any link to the little People image though!!
    Does look nice on the page 😀
    mfcphil Friend
    #301041
    Just a pointer on this:
    If it was not meant to have the little users image it would just be a blockquote style which would give us the quotation marks.
    The testimonial STYLE gives us the image and the quotation marks!!
This topic contains 8 replies, has 2 voices, and was last updated by  mfcphil 15 years, 8 months ago.
