Viewing 6 posts - 16 through 21 (of 21 total)
  • Ninja Lead Moderator
    #641504
    I found the problem on your site, there was conflict of jQuery lib version in t3 framework and I rollback T3 framework back to version 2.4.1 and the problem is resolved.
    and I have raised this of T3 framework V 2.4.8 to the dev team here and they will fix and release it next version.
    #740166
    Sincromyl Friend
    #575380
    Great! thanks! one more question..is this template Joomla 3.0 compatible? Will be hard to upgrade?
    Sincromyl Friend
    #641710
    Sincromyl Friend
    #740372
    #575411
    <em>@sincromyl 479898 wrote:</em><blockquote>Great! thanks! one more question..is this template Joomla 3.0 compatible? Will be hard to upgrade?</blockquote>
    Look at the link here you can see JA Sugite template can work with both JOOMLA versions 2.5 and 3.x.
    About migrating your site from 2.5 to 3.x you can follow this guide for reference here
This topic contains 21 replies, has 3 voices, and was last updated by  Sincromyl 9 years, 6 months ago.
