  • keane Friend
    #127215
    Hi, there, I tried to edit the sample testimonials and make it what I want…
    However, once i editted it, problems occured, could not format it properly at all..
    I tried to restore it by copying and paste “<blockquote class=”testimonial”><span class=”open”>At</span> id ut nunc Nullam Quisque Lorem congue metus volutpat mauris. <span class=”close”>Nulla.</span><span class=”author”><a href=”http://www.joomlart.com” target=”_blank” title=”Testimonial”>J.Frank</a></span></blockquote>
    <blockquote class=”testimonial”><span class=”open”>Lacinia</span> justo Donec porttitor Mauris vel risus velit neque Vestibulum <span class=”close”>fames</span><span class=”author”><a href=”http://www.joomlart.com” target=”_blank” title=”Testimonial”>F.Thomas</a></span></blockquote>
    <blockquote class=”testimonial”><span class=”open”>Lacinia</span> justo Donec porttitor. Justo Donec <span class=”close”>fames</span><span class=”author”><a href=”http://www.joomlart.com” target=”_blank” title=”Testimonial”>A.Landon</a></span></blockquote>”
    but you can see from my website, two problems:
    1. the cute icon of two people disappeared..
    2. the texts are narrower than they should be…
    any one can help? I think this testimonials can be developed into a module so that administrator can moderate without coding…
    keane Friend
    #244306
    Miccas just helped me sort this out!
    quiet simple, go to user management and turn off wyswyg editor and paste the coding in…
    thx heaps to Miccas and Miccas.net!
    kwoolf Friend
    #247572
    I have an issue, too. Very wierd. In IE7, if the text of the testimonial ends with the last word positioned directly over the author image or author text, the closed quote image won’t appear. But if the text of the testimonial extends past the author text (the author’s name) then the closed quote image will apear. Firefox doesn’t have this issue. Notice in your demo that all the text of every testimonial extends beyond the author’s name and the closed quote images all appear. I’ve tried editing the padding but it doesn’t work. If this was a problem with any other module, I would just add a few words, but these are testimonials and I can’t change them.
This topic contains 3 replies, has 2 voices, and was last updated by  kwoolf 16 years, 8 months ago.
