Viewing 15 posts - 1 through 15 (of 21 total)
  • sfpkent Friend
    #139117
    I have problem to figure out how to make those texts of articles before “Read More” show up in JA Body at frontpage.
    I am using JCE, I aligned those pictures to left (10px)
    Here is the link: http://worldwebcreator.com
    I have attached the problems (two image files).
    1. jabodyreadmore
    2. jabodyreadmore2
    sfpkent Friend
    #296032
    Anyone can help?
    sfpkent Friend
    #296554
    Helloo….
    JA staff, anyone expert. I have tried many times to modify this, modify that. Anyone?
    dorkyme Friend
    #297217
    I have the same problem!
    sfpkent Friend
    #297233
    Hi dorkyme,
    Would you mind provide your link as well?
    So JA staff or anyone else, who can help? Is this a bug in the JA Cooper template?
    sfpkent Friend
    #297243
    I have submitted a ticket to JA staff and hopefully they will answer our problem soon.
    Arvind Chauhan Moderator
    #297248
    Problem seems to have been solved. i just checked http://worldwebcreator.com and it looks the way you wanted. How did you resolve it?
    sfpkent Friend
    #297250
    I didn’t really solve the problem but I used stupid way to do it. There is no guarantee for this solution.
    We have to type or paste the test first, then pictures, if you put it the pictures first, the text before “Read More” won’t appear and you must use defauly article (the article created by JA), if you created a new articles, the problem appear again.
    That’s the reason I contact support to find the real solution. You may try, if you can find the right solution, pls post here so that everyone can benefit from your solution, thanks! 🙂
    dorkyme Friend
    #297251
    Maybe that is a solution for the problem, but that’s not how it should be. I do not have picture in all my articles.
    Hope support will answer and solve this problem as soon as possible. 😎
    sunrise Friend
    #297252
    Hi there sfpkent,
    I just installed JCE on a site I am working on and have not really tried it yet, but on an article that already works with read me, if I click on Show/Hide in the text editor and look at the html, it shows
    <hr id=”system-readmore” />
    where the “read more” goes.
    If you add that into the html it should work fine.
    I did not see a button though to add this, but maybe I didn’t look long enough.
    Hope this is a help.
    #297258
    I tried replicating it on localohost. I did not get the problem you faced.
    Here is the screenshot of my results :
    I added a new article. The steps i followed are as below.
    1. Downloaded & installed Ja cooper quickguide on localhost runing xampp 1.7.
    2. Copied, flipped the car image added line “new pic” so that it stands out from the original image.
    3. Installed JCE editor, jce plugin, JCE image extended plugin.
    4. Clicked on add new article.
    5. inserted the new (modified image).
    6. added the text and put in the read more after few lines.
    7. Published it to demo section>demo category and also on the front page.
    I did not put any alignment to the image nor to the text. I suggest you follow it once more and see if it helps.
    mneese Friend
    #297507
    I like all your sites and work.
    Please tell me where to find the editing for the words “welcome to the world web creator” that shows on the front page just below the slideshow.
    #297512
    <em>@mneese 119691 wrote:</em><blockquote>I like all your sites and work.
    Please tell me where to find the editing for the words “welcome to the world web creator” that shows on the front page just below the slideshow.</blockquote>
    In your admin panel. Click on Menus>> Main Menu>> Home>>
    On the right side you will see this :
    You must have written “welcome to the world web creator”. Change it to your taste.
    It it helps, let us know.
    mneese Friend
    #297519
    That works!
    #297529
    Ha Ha, That was easy. Glad it helped. The best way to learn joomla is to install it on your machine using Xampp and explore it around, crash it, repair it. Joomla is the easiest CMS available and Joomlart templates are a compliment to Joomla. They both when together rocks.
    cheers
This topic contains 21 replies, has 6 voices, and was last updated by  sfpkent 15 years, 9 months ago.
