  • maghautier Friend
    #121604
    I have two problems in the body of the JA Villadi template:
    – When I write a texte juste after a picture, the margin is “0”. Even if FCK Editor margins are “3” for example. When I trie to put a margin=3 in the CSS, all pictures in the template have a margin 3 (header for example…).
    How can I do just to applie a margin=3 in my body only for text behind pictures ?
    – When I create a board whith FCK Editor in my body page, it is all the time on the left even if I want it to be in center. What can I change in the CSS to respect FCK Editor’s instructions ???
    Thanks a lot,
    Best regards and sorry for my bad english !!
    Jérôme
    maghautier Friend
    #225273
    Please, is it possible to have a response ?
    Thanks a lot,
    Best regards,
    Jerome
    maghautier Friend
    #225460
    Is it possible to have an advise ???????
    Please !
    Jerome
    ErikThorsen Friend
    #225463
    Hello Jerome,
    You are asking for advice on a non Joomlart issue. This sometimes takes quite some more time to get replies to as it is not part of the official support. Not saying you will not get support, only the fact that it takes longer time to get the responses you want when asking about non Joomlart related questions.
    3rd party components/modules are not per definition supported on Joomlart so please have some more patience and hopefully someone can assist you with this.
    Personally I would recommend to use another editor. JCE is the leading ( and best ) editor out there and I REALLY, STRONGLY recommend to get the updated version ( paid support subscription one ) as this is the ultimate out there ( in my opinion )
    Try out with a few different editors to see if that can help whilst waiting for someone to help you out. You can also ( if you haven’t already done so ) post support help in the 3rd party developer site or even on the Joomla.org support site. Good luck and hope you will get some help soon!
    maghautier Friend
    #225597
    Ok I am going to test another editor or to have a response.
    Thank you.
    Jerome
This topic contains 5 replies, has 2 voices, and was last updated by  maghautier 17 years, 5 months ago.
