test melih
 melih
  • Pankaj Sharma Moderator
    #1084727
    it look like you have error in the less files,
    I suggest you to replace the less folder with fresh template package less folder and recreate the theme in Theme Magic.
    Also use latest version of T3 and Purity III template.
    cloudt3 Friend
    #1085034
    I did it, but it doesn’t work 🙁 Can you give me another solution please?
    • This reply was modified 7 years ago by  cloudt3.
    #1085395
    Kindly share the site super user details and FTP details in Private reply.
    I will check this issue.
    cloudt3 Friend
    #1085549
    #1085552
    You are not using the latest version of the T3 framework, Kindly check and update the T3 to the latest version.
    http://prntscr.com/hxj43g
    cloudt3 Friend
    #1085589
    Hi Pankaj, I’ve updated t3 framework to the last version (2.7.0) but Theme Magic still doesn’t work 🙁
    #1085675
    I disable some 3rd party extension on your site and its working fine.
    You can enable the extension one by one to see which extension causing the conflict. Also, there are 2 T3 plugin on your site i disabled one, not sure how you installed two plugins as there is only 1 T3 plugin we have.
    cloudt3 Friend
    #1086005
    Thanks a lot, Theme Magic problem is solved! 🙂
    The extension that interfered was "Folcomedia – Plugin use cookies alert".
This topic contains 8 replies, has 2 voices, and was last updated by  cloudt3 7 years ago.
The topic ‘Theme magic problems (strange preview site)’ is closed to new replies.
