  • leff34 Friend
    #184792
    Hello ,
    I can’t use theme magic on t3 v3 . On your demo site and local .
    Any idea
    leff34 Friend
    #483029
    Does someone can use thememagic with the t3v3 Rc2 on t3-framework.org ?
    Wall Crasher Developer
    #483156
    Hi leff34,
    Please open tpl_t3_blanklessmegamenu-responsive.less and add
    // VARIABLES & MIXINS
    @import “vars.less”; // Include Variables and Mixins
    to the top of file.
    This is an issue and we have fix on github.
    basdc Friend
    #485001
    I also have the same problem on local host using xammp. ja onepage.
    I am a newbe so any simple explanation as to how to fix would be much appreciated
    #485062
    Hi basdc,
    JA Onepage use T3v3 System Plugin. It does not compatible with T3 RC2.
    If you are installed T3 RC2, please remove it and use old T3v3 Framework.
    Please make sure you are enable T3v3 Framework.
    JA Onepage will release new version which using latest T3 Framework.
    You need to wait before upgrade your template.
    The upgrade document will be available with next release.
    basdc Friend
    #485122
    Thanks for quick response
    The T3v3 framework is the one it is now running on and it is enabled. Are you saying this is the wrong framework for the onepage template? I instaled it using quick install.
    Sorry for confusion
    thanks
    Barry:)
    #485175
    Hi basdc,
    New version for JA Brisk has been released. You can download and try the new version.
    For old JA Brisk, please check again that you have “Enabled ThemeMagic option”. You can also provide more information or screenshots for more info.
    basdc Friend
    #485315
    <em>@Wall Crasher 359743 wrote:</em><blockquote>Hi leff34,
    to the top of file.
    Regards</blockquote>
    Any chance you could give me the folder path as i dont seem to be able to find
    #485374
    Hi basdc,
    The folder was
    [JOOMLA ROOT]/templates/ja_brisk/less/
    and the file name is megamenu-responsive.less.
    If you does not see the megamenu.less and megamenu-responsive.less, you are using old version of JA Brisk. And I need your information to look into your server. (Pm admin/ftp information to me please)
    Hope it helps.
    basdc Friend
    #486048
    Thank you very much for your help with this one, it all seems ok now
    Much appreciated
    Barry
This topic contains 10 replies, has 3 voices, and was last updated by  basdc 11 years, 8 months ago.
