  • alioztr Friend
    #147323
    How can i translate Next: button text
    How can i remove date in janews
    How can i translate More: button text
    mumu0678 Friend
    #328467
    david892 Friend
    #332333
    I have the same question for the MORE text button. ANy help would be great!
    Anonymous Moderator
    #333386
    <em>@david892 164469 wrote:</em><blockquote>I have the same question for the MORE text button. ANy help would be great!</blockquote>
    If you open languageen-GBen-GB.mod_janews.ini file, you will see this text:
    MORE:=More:
    david892 Friend
    #333457
    That’s weird… I don’t have this file in the /language directory….
    In fact, I even looked in my backups and the en-GB.mod_janews.ini is nowhere to be found.
    And the MORE: text displays fine in my front end!
    Anonymous Moderator
    #333820
    Hi david892
    You copy en-GB.mod_janews.ini to your language and rename this file to your_language.mod_janews.ini
    At that time you can translate in that file
    david892 Friend
    #334260
    Well… 😮
    The file en-GB.mod_janews.ini is nowhere to be found in my language/en-GB directory! :confused:
    My JaNews module works fine except for that language “Problem”…
    Do I have to manually insert the file?
    Thanks for your help so far! Always nice to receive feedback from yoU!
    Anonymous Moderator
    #334573
    Hi you
    I think you are using an old version of module.
    You should download this module and install again
    david892 Friend
    #335715
    hmm.. From I see in my back end, I have version 1.3.1 (March 2008) of the JA News module. The version I have came with the template.
    Where can I download the most recent version? BEcause when I go in the downloads section @ http://www.joomlart.com/forums/downloads.php?do=cat&id=62, version number seems to be older!
    Finally,when I will install the newer version, will I be able to perform install without removing the old version first?
    Thanks!
    Anonymous Moderator
    #335909
    Hi david892
    We only update some files in this version. We don’t increase the number of version. Please download this package, backup your template and then install this template again.
    Hope it helps
This topic contains 10 replies, has 4 voices, and was last updated by Anonymous 14 years, 9 months ago.
