June 17, 2009 at 11:18 am #141976
Hi Guys,
I’ve installed JA_Larix with VirtueMart_1.1.3 on Joomla 1.5.9.
The problem is that none of the thumbnail images in the JA VM Product Slider module are displaying correctly – please see attached image to see what I mean.
When you click on the broken images and hit the individual product pages the thumbnail displayed there works just fine.
** ADDITIONAL INFO **
When I add a new product I have selected the “Auto-Create Thumbnail?” option when adding the Full Image – could this be the problem?I have searched thru the forum, but didn’t see a resolution that addresses my issue only one with regards to the “Enable Dynamic Thumbnail Resizing?” in the VM admin config, but that didn’t work here either.
Any help would be appreciated.
AP
mfcphil Friendmfcphil
- 388 times in 133 posts
June 17, 2009 at 12:43 pm #308174Is this something to do with a resized image folder….sure I read about this somewhere
June 17, 2009 at 2:59 pm #308187Thanks mfcphil, but I still can’t seem to locate the resolution..
Additional info – I have also noticed that the thumbnails in the “mod_virtuemart_featureprod” wont display either.
Screen dump attached..
- 1334 times in 848 posts
June 18, 2009 at 9:35 am #308267apottz;133057Thanks mfcphil, but I still can’t seem to locate the resolution..
Hi apottz,
Please edit your first post and add your site admin login details along with ftp access details, so that we can login and try to fix the problem. Also you can PM me the login details. It seems much more of folder path / permission / folder owner problem.
arvind
June 18, 2009 at 12:55 pm #308286Hi arvind,
I’ve just PM’ed you the account credentials, and FTP details as requested.
Regards,
AdamArvind Chauhan ModeratorArvind Chauhan
June 18, 2009 at 3:11 pm #308313Hi Adam,
It seems its Virtuemart problem. http://forum.virtuemart.net/index.ph…8346.msg182880
I set your joomla_root/components/ folder to 755 and it seems to be generating and showing the product thumbnails now.
Earlier it was set to 777.
Hope it helped.
regards
arvind
1 user says Thank You to Arvind Chauhan for this useful post
June 18, 2009 at 11:12 pm #308374Thanks arvind – much appreciated.
November 28, 2009 at 3:44 pm #325202Hi i was reading this post and i check my permisions in components file but its 755 ..i dont know why my products are not showing in my website.
Please help,
Maribel
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 4 voices, and was last updated by mariemusic 15 years ago.
