Viewing 15 posts - 1 through 15 (of 29 total)
  • timpennington Friend
    #681137
    I have a module at Home-2, but I don’t see where I can add a Title of the module where it shows up to name the module on the page.
    Here is an example:
    http://goturpin.com/index.php/fall/boys-soccer
    It is the photos of the individual players; how can I get the module to say “Boys Soccer”; the “Show Title” is on, but I don’t think the CSS has a setup to have a title for the module.
    Help?
    I changed style for module from inherited to html5 in advanced tab and now it is showing module title
    Is this correct ?
    Is this correct ?
    #681354
    Thanks for the help.
    This wasn’t exactly what I was looking for; I wanted the RED module heading that appears throughout. I thought this would be CSS issue.
    But I saw one other issue; if I have more than 1 home-2 module on the same page, they won’t stack on top of each other like other modules will do; they seem to just connect and be 1 big run-on module; see the photo where two modules are in Home-2 and one of them is named Girls Soccer JV Gold and the other is Girls Soccer Maroon, and the Girls Soccer JV Maroon is stacked on the far right.
    #747291
    The best way to solve this is to create a new template layout copying default template and add to it new blocks home-4 home-5
    edit this file/templates/ja_teline_v /tpls/blocks/mainbody.php and rename it mainbodysoccer.php
    <?php if ($this->countModules('home-2')) : ?>
    <div class="wrap <?php $this->_c('home-2') ?>">
    <div class="container">
    <jdoc:include type="modules" name="<?php $this->_p('home-2') ?>" style="raw" />
    </div>
    </div>
    <?php endif ?>
    <?php if ($this->countModules('home-3')) : ?>
    <div class="wrap <?php $this->_c('home-3') ?>">
    <jdoc:include type="modules" name="<?php $this->_p('home-3') ?>" style="raw" />
    </div>
    </div>
    <?php endif ?>
    CHANGE TO :
    </div>
    </div>
    <?php endif ?>
    </div>
    </div>
    <?php endif ?>
    <?php if ($this->countModules('home-4')) : ?>
    <div class="wrap <?php $this->_c('home-4') ?>">
    <jdoc:include type="modules" name="<?php $this->_p('home-4') ?>" style="raw" />
    </div>
    </div>
    <?php endif ?>
    Then open this file /templates/ja_teline_v /tpls/default.php and copy it as defaultsoccer.php
    change the :
    <?php $this->loadBlock('mainbody') ?>
    TO :
    <?php $this->loadBlock('mainbodysoccer') ?>
    Then in your new template layout choose the defaultsoccer layout
    In this way you can publish your modules as you wish
    </div>
    </div>
    <?php endif ?>
    </div>
    </div>
    <?php endif ?>
    CHANGE TO :
    </div>
    </div>
    <?php endif ?>
    </div>
    </div>
    <?php endif ?>
    </div>
    </div>
    <?php endif ?>
    change the :
    TO :
    #681383
    Just to be sure, will this new “template” layout affect the rest of my site other than the changes you suggest?
    #747320
    <em>@timpennington 490216 wrote:</em><blockquote>Just to be sure, will this new “template” layout affect the rest of my site other than the changes you suggest?</blockquote>
    Nothing else will be affected , you have new files and these files will be used ONLY on menu items with assigned template using NEW LAYOUT
    #681777
    Ok, I did what you directed; I don’t think it worked
    1. I went to the template and selected the defaultsoccer layout
    2. I went to the modules and changed them to Home-4
    3. On this page: http://goturpin.com/index.php/fall/girls-soccer/girls-soccer-jv the modules are still misaligned; Girls Soccer JV Maroon is still hanging out on the far right where the sidebar is
    What did I not do correctly?
    #747562
    each module in one position
    home-4 publish 1 module
    home-5 publish 1 module
    home-6 publish 1 module
    at the same way you added the home-4 position you can add new positions home-5 , home-6 , home-7 and so on
    in this way each module will be under each other , not 2 modules in the same position
    Hope was clear in all my posts
This topic contains 29 replies, has 3 voices, and was last updated by  Adam M 9 years, 4 months ago.
