Viewing 14 posts - 16 through 29 (of 29 total)
  • timpennington Friend
    #681780
    “Girls Soccer JV Gold” is in Home-4
    “Gitls Soccer JV Maroon” is in Home-5
    I changed to that above, and now there is a BIG hole in the middle of the page, and Home-4 shows up, but Home-5 does not.
    #747565
    There is no Home-5 position available at the defaultsoccer layout as you can see here
    The empty space on page is because there is a sidebar module published on that page
    I added the Home-5 position and created a new layout template named JA Teline V – Default-Soccer and assigned it to the Girls Soccer JV menu item
    remove the sidebar module and assign the “Girls Soccer JV Gold” in Home-4 and “Gitls Soccer JV Maroon” is in Home-5 and in page assignments
    check your page now
    check your page now
    #681787
    So if I have a sidebar, I can’t use Home-2 or others?
    Any work around of that? That seems bad
    #747572
    <em>@timpennington 490588 wrote:</em><blockquote>So if I have a sidebar, I can’t use Home-2 or others?
    Any work around of that? That seems bad</blockquote>
    Check the blog layout it has sidebar on the right that will cover all the space , as per your needs apply the same changes i suggested for default layout creating a new blog layout for your specific page
    Hope was clear
    Hope was clear
    #681792
    I just don’t follow your last instructions
    #747577
    Adam M Moderator
    #682849
    Hi @timpennington,
    Could you please confirm your status ?
    Adam M Moderator
    #748092
    Hi @timpennington,
This topic contains 29 replies, has 3 voices, and was last updated by  Adam M 9 years, 4 months ago.
