  • ghjulianu Friend
    #176819
    I want to put a module at the “ja-news-1” position, but if I do it the title of the module is not displayed.
    It seems that titles on the “ja-news-x” positions only appear if JA News Pro! Module is used, that’s it?
    So how could I do? Thanks.
    HeR0 Friend
    #452171
    I can see template layout configuration set is <block name=”content-mass-top” style=”raw” type=”tabs”>ja-news-1,ja-news-2,ja-news-3</block>. If you want to display title, please remove style=”raw”
    Please access to backend => template manager => JA_Teline_IV => Layout (Tab) => edit layout defalt
    Regards,
    ghjulianu Friend
    #454430
    I tried to put a module at the ja-news-x position but my module is not displayed properly.
    Is there a CSS style for the ja-news-x positions? If yes, how to disable it? Thanks in advance.
    HeR0 Friend
    #454492
    <em>@ghjulianu 321514 wrote:</em><blockquote>Hi,
    Is there a CSS style for the ja-news-x positions? If yes, how to disable it? Thanks in advance.</blockquote>
    => Please make sure that you clean all cache after change setting and check front end again
    Regards,
    ghjulianu Friend
    #454585
    I did what you said but the problem still remain.
    My site: http://bit.ly/ytlxhi > The module “Vidéos” is not displayed properly. It should normaly be displayed as it shown here: http://bit.ly/s6QKnr (under the slider).
    Could you please help me on the CSS codes to modify? Thank you.
    HeR0 Friend
    #454828
    <em>@ghjulianu 321708 wrote:</em><blockquote>Hi,
    Could you please help me on the CSS codes to modify? Thank you.</blockquote>
    Please provide admin, ftp account then i shall help you fix it. I think that your module setting is incorrect.
    ghjulianu Friend
    #454979
    I just sent you a PM. Thanks in advance.
    HeR0 Friend
    #454996
    <em>@ghjulianu 322201 wrote:</em><blockquote>Hi,
    I just sent you a PM. Thanks in advance.</blockquote>
    Hi Ghjulianu
    I fixed on your site, please check again.
    Note: this module is Gavick product so i think that you should get support from Gavick team in future.
    Regards,
    ghjulianu Friend
    #455035
    Hi HeR0,
    Thank you very much! 🙂
    What was wrong? (module or “conflict” with the template)
    HeR0 Friend
    #455124
    <em>@ghjulianu 322273 wrote:</em><blockquote>Hi HeR0,
    What was wrong? (module or “conflict” with the template)</blockquote>
    Hi Ghjulianu
    The module style sheet was not good, so i modified it little bit (dont remember now what).
    Regards,
This topic contains 10 replies, has 2 voices, and was last updated by  HeR0 12 years, 7 months ago.
