  • ftmmarketing Friend
    #172798
    So I got the live slide going after some in-depth testing but I think I just messed up big time. I installed K2 because it looked like in the guide it was needed for user comments (how do you even turn that on??) but after I did it killed my slideshow, T3 bar at the top & even google maps plugin.. do I need to nuke this whole dumb site and start over again?!
    http://new.facethemag.com/
    TomC Moderator
    #433870
    I’m not certain how installing the K2 component would affect your slideshow – unless you attempted some configurations linking the two. What configurations might you have enacted?
    ftmmarketing Friend
    #433937
    I got most of it fixed. I don’t want to bad mouth this template because I love its design but jesus its been kicking me in the ace.
    How do I turn comments on? I can’t figure it out, or if its on why am I not seeing the comment box, do I need to install something?
    TomC Moderator
    #436681
    How to enable/disable JA Comment for specific content items
    • Use {jacomment on} by adding this code at the end of the content items (articles) to enable JA Comment for these articles, even if JA Comment is disabled for the category of those articles.
    • Use {jacomment off} by adding this code at the end of the content items (articles) to disable JA Comment for these articles, even if JA Comment is enabled for the category of those articles.
This topic contains 4 replies, has 2 voices, and was last updated by  TomC 12 years, 10 months ago.
