May 10, 2015 at 10:12 am #570031Hi
Could you try now ?
pavit Moderatorpavit
May 10, 2015 at 10:12 am #735103Hi
Could you try now ?
May 10, 2015 at 10:36 am #570032That’s fantastic it works now
What did you change?May 10, 2015 at 10:36 am #735104That’s fantastic it works now
What did you change?pavit Moderatorpavit
May 10, 2015 at 10:39 am #570033<em>@damaskmedia 472672 wrote:</em><blockquote>That’s fantastic it works now
What did you change?</blockquote>I changed div class inside spotlight-2.php file and added custom class .t3-module.newtop ( newtop ) inside custom.css to reduce padding for modules .
May 10, 2015 at 10:39 am #735105<em>@damaskmedia 472672 wrote:</em><blockquote>That’s fantastic it works now
May 10, 2015 at 12:46 pm #570037I tried to remove this gap using the following code:
.newtop.t3-module .col-md-6 {
padding-right: 0px !important
padding-left: 0px !important}
but the gap still seems to be there. any ideas on how i can remove it?
thanks
May 10, 2015 at 12:46 pm #735109I tried to remove this gap using the following code:
thanks
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
May 18, 2015 at 7:22 pm #570985Hi @damaskmedia,
I didn’t see these blocks in your site, could you please enable them so I can check ?
AuthorPostsThis topic contains 24 replies, has 3 voices, and was last updated by damaskmedia 9 years, 8 months ago.
