tworld Friend
tworld
- October 2011
November 28, 2011 at 6:07 pm #171191I’ve added a special CSS rule to change the link and background color of the top-level links on my Mega Menu, like this:
ul.level0 li.mega a.haschild:focus, ul.level0 li.mega a.haschild:hover { {
color: #fff;
background-color: #006699 !important;
}But when I move my cursor over the sub-menu links, the background color of the top-level links disappears. What other CSS rule do I need to define to fix this problem? See attached image.
khoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
November 29, 2011 at 11:09 am #427118You replace your code with
ul.level0 li.haschild-over a.over {
background: #069;
color: white;
}tworld Friendtworld
- October 2011
November 29, 2011 at 5:32 pm #427181This also puts the same background color for the sub-menu, though. I want to sub-menu to stay the way they are, the only thing I want to change is the top level. I tried adding the following, but it doesn’t work:
.ja-megamenu ul.level1 li.mega a.over, .ja-megamenu ul.level1 li.mega a:hover, .ja-megamenu ul.level1 li.mega a.over span.menu-title {
background: none repeat scroll 0 0 transparent;
khoand Friendkhoand
- February 2011
November 30, 2011 at 9:46 am #427301You just use my code, like that
color: black;
tworld Friendtworld
- October 2011
November 30, 2011 at 3:22 pm #427341Your code doesn’t do what I want. What I want is this:
– level0 background color to be #006699 and level0 text color to be white
– level1 links background color to be transparent and the link colors to be same as default
– also, when the cursor moves to level1 links i want level0 background color to STAY #006699 and level0 text color to STAY whiteI thought the last CSS rule I showed you would work, but it doesn’t because there is another rule that is overriding it for some reason.
So, is what I want possible with the Mega Menu? It seems it should be, but I am not sure which rules target the level1 links and background colors of those links ( <a> and <span> tags) properly.
khoand Friendkhoand
- February 2011
December 3, 2011 at 10:22 am #427705I understand what you mean. You try this way:
– You remove this code from /templates/ja_ores/local/themes/trauma-world/css/menu/mega.css
ul.level0 li.mega a:hover, ul.level0 li.mega a:active, ul.level0 li.mega a:focus, ul.level0 li.mega a.sfhover {
color: #353535;
– You replace this code from /templates/ja_ores/local/themes/trauma-world/css/light-theme.css
color: white;
with
background: #069;
color: white;
}1 user says Thank You to khoand for this useful post
tworld Friendtworld
- October 2011
December 5, 2011 at 8:43 pm #428081Yup, that fixed the problem. Thanks!
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by tworld 13 years ago.
Top Level Mega Menu Links Background Color Disappears When Hovering Over Sub-Menu
