  • emanuel JATC
    #116776
    Please check http://www.wyszak.com. This is an initial test installation. The top menu display does not work correctly on IE (it does work on Mozilla). It shows only one button at the time. Is there anything I missed during install?
    Thank you,
    Emanuel
    nathanbohn Friend
    #209565
    i believe its due to the amount of buttons in the menu. Try taking out a menu button so its not on two layers
    alberts Friend
    #209582
    Yes, that is defintely the problem. I’ve noticed the same thing. You have to make sure you don’t have too many menu items, or else it doesn’t work right.
    emanuel JATC
    #209601
    Thank you guys… that did it..:D
    prakdis Friend
    #210003
    Thanks Nathan and Albert.
This topic contains 5 replies, has 4 voices, and was last updated by  prakdis 18 years, 3 months ago.
