  • the white alchemist Friend
    #127512
    Hi all. I have a problem with the topmenu. I put a denvideo module on the ja-news side an right over the headline. Everything works fine but with the Moo template, when u select a menu it deploy behind the denvideo module. how ca i put the topmenu over the denvideo module?
    thnx
    #245337
    your site is off line, I can’t view it.
    #245421
    Sorry. I’m changing server and it will be online this week. I’m using easyphp and building the site offline.
    #245444
    Ok. I just change the menu order so that specified menu opens over the right side of the screen instead over the video module and the headline. It will work for now until i put online the site so you can see it with your eyes.
    Thanks!
This topic contains 4 replies, has 2 voices, and was last updated by  the white alchemist 16 years, 8 months ago.
