May 20, 2010 at 1:32 pm #151206
Hi,,
Please see the attached file for the issue i am having … i have tried insatalling on different servers and faced the same problem.
Thank you,
Rani
May 31, 2010 at 12:40 pm #345377I have the same problem. Is there a fix for this?
uniquebiz Frienduniquebiz
- February 2010
- 156 times in 119 posts
May 31, 2010 at 12:45 pm #345378rani;179248Hi,,
Please see the attached file for the issue i am having … i have tried installing on different servers and faced the same problem.
Thank you,
RaniHi Rani can we have a live site url please and what browser are you using, does this happening in all browsers? etc
Screen shots and ‘I have a problem’ don’t give us source code to see or test in 3 major browsers
I’m sure you understand
Blessings ShannonMay 31, 2010 at 12:50 pm #345379<em>@uniquebiz 180790 wrote:</em><blockquote>Hi Rani can we have a live site url please and what browser are you using, does this happening in all browsers? etc
Blessings Shannon</blockquote>This was happenning all browsers and i got the fix from joomlart support time which i am going to post below.
May 31, 2010 at 12:50 pm #345380The Fix:
1, Open the file “templates/ja_rasite/css/color/YOUR_DEFAULT_COLOR.css”
Note: YOUR_DEFAULT_COLOR is the name of color that used on default site, eg: light_ocean.2, Find the code:
ul.level1 li.mega a.mega span {
and replace by:
background: none !important;3, Save the file then refresh your site.
May 31, 2010 at 12:55 pm #345382AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 3 voices, and was last updated by willhaigh 14 years, 4 months ago.
top menu problem
