  • mclaren Friend
    #119366
    How to add a top module position?
    I would like to have top module position, just below the main menu. Please tell me what code should I add to index.php in order to have such module
    Thanks you:
    swemmel Friend
    #217925
    In my example the new module-position is called fpss. Oke, here we go.
    Search in the index.php to the following code:
    </div>
    <div id="ja-content">
    <?php mosMainBody(); ?>
    <?php if ( mosCountModules('banner') ) { ?>
    <!-- BEGIN: BANNER -->
    <div id="ja-banner">
    Put the new module between <div id=”ja-content”> and <?php mosMainBody(); ?>. See below.
    </div>
    <?php if( mosCountModules('fpss') ) {?>
    <?php mosLoadModules('fpss', -2); ?>
    <?php } ?>
    In the backend of your site fo to Site – Template Manager – Module Positions and add in an empty field fpss
    Now you can publish a module there, the result is as in the picture (to see it live: http://naaktgeboren.swemmelaar.nl)
    Kind Regards,
    Peter
    375
    1. Clipboard01
    yuccalab Friend
    #222272
    gosh…..I am glad to see this post. I have been trying to get fpss working in my environment and everyone was telling me it was my utah ii template. I have installed the mod and component to a t and am unable to get it to work. I am getting the swirling loading when I publish it in my banners area. did you do anything special to fpss to get it working within the template?
    -Jarrod
    swemmel Friend
    #224917
    Hi Jarrod,
    No I didn’t do anything special. But you can search on the forums on JoomlaWorks. I believe I have seen more questions about this problem there.
    Kind Regards,
    Peter
    Sorry for late reply, but I was on vacation. 😉
    eka_template Friend
    #226145
    Dear Peter,
    Thanks for your wonderful posting and help. I am looking for this modification too. But as I am new, I am still learning to make modification like you did. I am sure I will get it. It will be really helpful if I can have your index.php file and related CSS files you modified for me to study. Is that possible Petter?
    Thanks in advance for your help and kindness.
    Best regards,
    Eka
    **************@yahoo.com
    swemmel Friend
    #226147
    eka_template;23272Dear Peter,
    Best regards,
    Eka
    Hi Eka,
    I did send the index.php to your email-adress.
    Kind Regards,
    Peter
    rodboyd Friend
    #230012
    Great work Peter – and it was soooo simple! 😀
    swemmel Friend
    #230025
    Thanx. 😉 Glad I could help.
    fderycke Friend
    #230046
    Thank you very much for this post : this is exactly what I was looking for weeks ! 🙂
This topic contains 9 replies, has 6 voices, and was last updated by  fderycke 17 years, 3 months ago.
