milsirhc Friend
milsirhc
- January 2011
- 2 times in 1 posts
February 23, 2011 at 2:23 am #160584Hi,
I’m trying to add the Top Panel Module to the top right hand corner like (digitalbloom.ca) but unable to find a module position to do that.
Will really appreciate if someone can guide me on how to do so.
Many thanks.
Saguaros ModeratorSaguaros
February 23, 2011 at 7:18 am #378045You try to use the ja top panel module: http://www.joomlart.com/forums/downloads.php?do=cat&id=20350
To resolve the issuemilsirhc Friendmilsirhc
- January 2011
February 23, 2011 at 10:50 am #378095I’ve downloaded the top panel module, however I can’t put it in the top right position in rasite on J1.6.
Do I have to create a block for it specifically?
- January 2011
February 23, 2011 at 9:56 pm #378161Anyone know how to achieve this?
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
February 23, 2011 at 11:30 pm #378171Can you post a link to your page so I can look at the css and test some adjustments? Please make sure optomize css is set to “No” in the template manager.
- January 2011
February 24, 2011 at 1:41 am #378189<em>@phill luckhurst 223451 wrote:</em><blockquote>Can you post a link to your page so I can look at the css and test some adjustments? Please make sure optomize css is set to “No” in the template manager.</blockquote>
Hi Phil,
Have pm’ed you.
Thanks mate!
February 24, 2011 at 3:22 am #378204You access the template configuration and edit the Default Layout
you find:
<blocks name=”top” style=”xhtml”>
replace by:
<block name=”top-panel” type=”modules” style=”jaraw” main-inner=”1″>top-panel</block>When done: you read the guide at the topic “3. JA Top Panel Module: (Position: top-panel)” :http://www.joomlart.com/forums/topic/ja-social-userguide-old/
- January 2011
February 24, 2011 at 9:43 am #378258Thanks for looking into this. Really appreciate your help.
Managed to edit the CSS to move it to the right.
Can I ask how do I make the slider content width smaller? I only have the login module in there and want to get rid of the empty area on the right.
- January 2011
February 25, 2011 at 5:17 am #378371Managed to fix this myself.
Thanks.
- 2008 times in 1700 posts
February 28, 2011 at 5:57 am #378735Hi, glad to hear you have get it solved :). Would you mind sharing your solutions here so that others could overcome similar problems if occured.
- January 2011
February 28, 2011 at 3:28 pm #378888<em>@JA Developer 224243 wrote:</em><blockquote>Hi, glad to hear you have get it solved :). Would you mind sharing your solutions here so that others could overcome similar problems if occured.</blockquote>
Sadly, it did not work 100% as it loads OK in chrome but different position in IE.
Can you help me with it? If it’s too hard to align it correct, maybe it can take the position of the CPanel? Can that be done easily?
This topic contains 12 replies, has 4 voices, and was last updated by milsirhc 13 years, 9 months ago.
