  • sky Friend
    #942715
    I put a easy social login module on the top, but the facebook button could not align well
    Pankaj Sharma Moderator
    #942718
    because the facebook button is not the part of the top items , its defined i the code like this way .
    Take a look in my screenshot you can see the button is defined below in the code : http://prntscr.com/bjekuj
    You need to check the php code of login module with help of the extension support team and change position of it .
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 5 months ago.
