  • Dean Clarke Friend
    #135562
    Im using fedora/joomla 1.5.8 and virtuemart 1.1.2.
    Each of my pages on my site http://www.newwomens.net has a diferent picture in the topsl module – basically several different modules which have pictures in them, and then I assigned the modules to the page on my choice…apart from the homepage which has a scrolling slideshow.
    Hope you are with me so far…
    Now, the only page I cant assign a module to in the topsl position is the shopping cart page – if you try and buy something and then go straight to checkout you will see what I mean.
    How can I get around this??
    If I assign 1 module to ALL pages in the topsl module position then it works – it only seems to not work when I specify the pages.
    Cheers.
    Dean Clarke Friend
    #279827
    OK – I disabled AJAX in virtuemart – this works fine.
This topic contains 2 replies, has 1 voice, and was last updated by  Dean Clarke 16 years, 1 month ago.
