December 7, 2011 at 3:29 pm #171566
Hello
I am using this component a few days ago and i cant find where to translate some fields of the JAJobboard menu, i have the en-EN file i translated it but still i am missing some strings, Particulary what i need to translate is the “Register as a joob seeker” string which i cant find anywhere not even on the main file provided in the backend administration com_jajobboard.ini
Please help me. Thanks.
khoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
December 7, 2011 at 4:55 pm #428467You change the code from /language/en-GB/en-GB.mod_jajobboard_menu.ini
REGISTER AS A JOB SEEKER=Register as a Job Seeker
December 7, 2011 at 6:44 pm #428498I have modified the file, but i see exactly the same string there is no change at all. Ive cleared cache both in joomla and in my 2 browsers, and i see the same. Please check http://tebuscopega.bithost.cl/alt
Also how can i change the order of the locations?
Thanks.
khoand Friendkhoand
- February 2011
December 8, 2011 at 11:02 am #428668Could you give me username+password of your backend and ftp? I will check it. Because I tested it on my localhost and it works normal.
December 9, 2011 at 12:20 pm #428947Hello
I sorted it out was a problem with the file location, now i have a similar problem and its when it comes to register as a job seeker, i cant translate the steps of payment (select subscription, resume information, payment) also the title Register as a jobseeker cant find the string.
Thanks.
khoand Friendkhoand
- February 2011
December 9, 2011 at 2:39 pm #428963I can’t help you if you don’t give me username+password of your backend and ftp. Sorry about inconvenience.
December 9, 2011 at 3:51 pm #428985site access sent via pm
khoand Friendkhoand
- February 2011
December 10, 2011 at 11:59 am #429085You change the texts from /templates/gk_quay/html/com_jajobboard/jauserregister/regjobseekerform.php
<span style="width:40%; float:left"><a href="#" onclick="changeStep(1);" id="link1"><h2> <?php echo JText::_("1. Select Subscription");?> </h2></a></span>
<span style="width:40%; float:left"><a href="#" id="link2"><h2> <?php echo JText::_("2. Resume Information");?> </h2></a></span>
<span style="width:20%; float:left"><a href="#" id="link3"><h2> <?php echo JText::_("3. Payment");?> </h2></a></span>December 15, 2011 at 2:05 pm #429740That worked, thank you.
Now i want to hide the Time zone field on the resume information form, but i cant find that field in the form customizations section in the component, where can i find it?
Thank you.
khoand Friendkhoand
- February 2011
December 17, 2011 at 8:52 pm #430107To help forum is clearly, you create a new thread for your new issue, please. After that, you inform me, I will help you. Thank you.
<em>@bithost 289283 wrote:</em><blockquote>That worked, thank you.Now i want to hide the Time zone field on the resume information form, but i cant find that field in the form customizations section in the component, where can i find it?
Thank you.</blockquote>
This topic contains 10 replies, has 2 voices, and was last updated by khoand 12 years, 9 months ago.
