Samir Mastaliyev Friend
Samir Mastaliyev
- April 2014
January 10, 2010 at 1:24 pm #147510hi.
i need to know where the file that contain that word is in order to translate them.
1) You are here
2)More
p.s. please see attachment
gray Friend
gray
- October 2009
- 292 times in 230 posts
January 10, 2010 at 2:39 pm #3288661) In templatesja_teline_iiilayoutsblocksmainnav.php find & change
<div class="ja-breadcrums">
<strong>You are here:</strong> <jdoc:include type="module" name="breadcrumbs" />
</div>
2) in modulesmod_janews2tmplblog_item.php find & change
echo "<strong>More:</strong>n";
2 users say Thank You to gray for this useful post
Samir Mastaliyev FriendSamir Mastaliyev
- April 2014
January 10, 2010 at 3:52 pm #328870mujik, ti kajetsya ot a do z znayesh etot dvijok ))
mojet znayesh kak smenit favorit.ico ? na 1.0 lekqo menyalos ,a na 1.5 ne znayu qde iskat. to chto na papke template ne pashet.gray Friendgray
- October 2009
January 10, 2010 at 8:17 pm #328900Please read this document about changing the favicon.
PS. in Teline III simple replacement of templatesja_teline_iiifavicon.ico should work.
1 user says Thank You to gray for this useful post
- April 2014
January 13, 2010 at 8:53 pm #329244somebody,please tell me how to change the word in the top of the Ja teline III “Headlines” ?
and also how to change the date translation ?
micrantha Friendmicrantha
- May 2007
- 158 times in 148 posts
January 14, 2010 at 9:23 am #329284Hello mastaliyev,
“Headlines” is coded in different files for the different versions of Jateline III:
version 1.3: in layouts/blocks/header.php
There it is coded as JTEXT; look for this line<em><?php echo JText::_('Headlines')?></em>
So you could change it automatically in a language file.
version 1.4: in site/modules/jmod_janewsticker/tmpl/default.php
look for this line:<em><?php echo $params->get('headtext', 'Headlines:'); ?></em>
In this template-version the module seems to be updated too, so it is now a parameter in the module-configuration: last item: HeadText
For date-configuration see this extensive thread.
good luck,
Micrantha1 user says Thank You to micrantha for this useful post
February 1, 2010 at 2:10 am #331081<em>@gray 159841 wrote:</em><blockquote>1) In templatesja_teline_iiilayoutsblocksmainnav.php find & change
</div>
</blockquote>
Gray
Thanks for your reply. It helps me so much and I could change the “you are here ” as you told us. Thanks!!!:D -
Viewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 4 voices, and was last updated by carmila 14 years, 11 months ago.
