Viewing 15 posts - 1 through 15 (of 19 total)
  • franckyky Friend
    #168603
    I have a little problem with JAcomment about the translation of certain words
    For exemple :
    “Quote” : translate in french
    “comment as a guest” : no translate
    “Reply” : translate in french
    “submit comment” : no translate
    The variables are in “fr-FR.com_jacomment.ini” and the translation too …
    I don’t understand. Can anyone Help me please ?
    Joomla 1.7.0 JA Comment 1.1.0
    Franck
    1. jacomment
    jooservices Friend
    #412986
    hi
    there are missed some translate code
    lets me check it
    thank you
    viet vu
    jooservices Friend
    #412991
    Would you mind update me a page you are talking about ?
    Thank you
    Viet Vu
    franckyky Friend
    #412992
    you can see an exemple here :
    http://www.stephanequerioux.fr/index.php/actualites/151-concoursq-les-voix-de-la-chance-q#jacommentid:4
    the component has some words in french and some in English
    also the tooltips
    jooservices Friend
    #412995
    I’ve just checked into code
    <span class="jac-form-guest">
    <label for="guestWebsite"><?php echo JText::_("TEXT_WEBSITE");?></label>
    <input id="guestWebsite" name="website" type="text" class="field text inputbox jac-inner-text" value="<?php echo JText::_("TEXT_WEBSITE");?>" size="18" tabindex="4" title="<?php echo JText::_("OPTIONAL_TEXT"); echo JText::_("IF_YOU_HAVE_A_WEBSITE_TEXT");?>" />
    <input type="hidden" value="<?php echo JText::_("TEXT_WEBSITE");?>" id="jac_hid_text_website">
    </span>
    <input type="button" class="btTxt" tabindex="9" onclick="postNewComment()" title="<?php echo JText::_("POST_NEW_COMMENT");?>" id="btlAddNewComment" value="<?php echo JText::_("SUBMIT_COMMENT");?>"/>
    Actually it’s already used JText for translate able.
    Would you mind check in fr language file have these translate string ?
    Thank you
    Viet Vu
    franckyky Friend
    #412999
    Sorry but I don’t understand … 🙁 What is JText ?
    Franck
    jooservices Friend
    #413000
    JText is a Joomla function to make text can translate able.
    As my code posted above, our JA Comment already for translate able. I see have no issue here.
    But would you mind check in your fr language file , does it already have these translate text for all of above ?
    For sample:
    TEXT_WEBSITE = 'your translate'
    OPTIONAL_TEXT = 'your translate'
    Thank you
    Viet Vu
    franckyky Friend
    #413003
    ok thank’s for the information about JText
    in fr-FR.com_jacomment.ini I have this :
    TEXT_WEBSITE="Site Web"
    OPTIONAL_TEXT="(Optionnel) "
    jooservices Friend
    #413007
    Yo
    Please translate it into your Fr language 😀
    Thank you
    Viet Vu
    franckyky Friend
    #413009
    The problem is they are already in the FR language .ini :((
    on the website :
    TEXT_WEBSITE is translate by “site web” -> ok
    OPTIONAL_TEXT is no translate “(optional)” instead of “(optionnel)”
    that’s why I don’t understand
    PS :
    I use Notepad++ to edit my file, ’cause by the backend, the translation is no longer on the site
    jooservices Friend
    #413010
    Let’s me check.
    Because i’ve tested my local and everything working well.
    ps:// got root for your contact issue
    Notice: Undefined property: stdClass::$email_to in components/com_contact/controllers/contact.php on line 127
    Thank you
    Viet Vu
    jooservices Friend
    #413011
    Got
    Thank you sir, now i’ve reason to kill dev team.
    please check into file
    templates/ja_methys/html/com_jacomment/themes/methys/html/comments/addnew.php
    Please replace line 112 by below code
    Reason. In template override dev put wrong translate string.
    Thank you
    Viet Vu
    franckyky Friend
    #413017
    It’s works !!!!!!
    Thank you very much VietVu 😎
    Now I must do the same for the button “submit comment” who’s not translated, the text “Comment as a guest or” and other tooltips.
    I’ll try to search for, now that I have some clues.
    Thank you for your help, I’m sorry to leave but in France it is 05:30 am.
    there are 20 hours that I’m up….
    I’ll go to sleep a bit and I stay in contact for the contact form problems
    Thanks again Vietvu
    sincerely
    Franck
    jooservices Friend
    #413019
    You are welcome.
    Thank you
    Viet Vu
    nosyweb Friend
    #413114
    Hi franckyky,
    Do you have Joomla 1.7 ?
    I would like to translate the french .ini file. Are you ok to translate it together ?
This topic contains 19 replies, has 3 voices, and was last updated by  nosyweb 13 years, 3 months ago.
