  • Parisi Friend
    #978776
    Hello
    this temp here is giving problems with the translation , the frontsite insists to be only in english even if i set my lang on the back admin. it shows like this http://site.com.br/newsite/index.php/en/
    /en/ means english , so , it show all in english , could you help me with that please
    Pankaj Sharma Moderator
    #978826
    Did u created the the content (articles and category)
    /modules/
    menu/
    template style for EN language ?
    At this time it seems the site content is only for one language , you have to create separate content for each language .
    Also i suggest you to do not update Joomla3.6.3 since template is not ready for it , wait for official update for Joomla3.6.3 .
    Parisi Friend
    #979011
    #979017
    You have to create
    3 menu
    1. 1 for EN language that has only EN language menu item
      1. one for PT-BR language , that has only pt language menu item .
      1. One Main menu that has only one menu item , that is Home menu for all language .
    2. Tutorial : http://www.slideshare.net/erictiggeler/creating-a-multilingual-site-in-joomla-joomla-3-beginners-guide-eric-tiggeler
      Doc. Here
    Parisi Friend
    #979023
    #979307
    i checked your site , you do not have multi-language menu item and content .
    Kindly create the separate menu item for EN and Pt language .
    And article and category and modules too for each language : http://prntscr.com/cxq9oe
    At present, the menu item language is set to All : http://prntscr.com/cxq95c
    You can follow the links from my last post to see how to make a multilanguage site on Joomla .
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 2 months ago.
