  • africabizz Friend
    #155907
    Could anybody help please? there is a problem with the translation in french. i have created a file fr.FR.ja_login.ini and translate the text in french yet some texts are not translated. there is even a translation that i don’t understand. here are the problematic texts:
    • NAME
    • ENVOYER
    • VERIFY PASSWORD
    • Fields marked with an asterisk (*) are required.
    You can see the screenshot attached to my message.
    Thank you in advance!
    1. screenshot
    <em>@africabizz 201328 wrote:</em><blockquote>Could anybody help please? there is a problem with the translation in french. i have created a file fr.FR.ja_login.ini and translate the text in french yet some texts are not translated. there is even a translation that i don’t understand. here are the problematic texts:
    • NAME
    • ENVOYER
    • VERIFY PASSWORD
    Thank you in advance!</blockquote>
    Hello
    Please Open the file: templatesja_socialhtmlmod_jalogindefault.php
    and find the following code:
    [PHP]
    <?php echo “Fields marked with an asterisk (*) are required.”; ?>[/PHP]
    and replace:
    [PHP]
    <?php echo JTEXT::_(“Fields marked with an asterisk (*) are required.”); ?>
    [/PHP]
    2) you can make those translation text into the Global of current Language file: languages/YOURLANGUAGECODE/YOURLANGUAGECODE.ini
    africabizz Friend
    #361272
    <em>@tienhc 201426 wrote:</em><blockquote>Hello
    [PHP]
    and replace:
    [PHP]
    [/PHP]
    2) you can make those translation text into the Global of current Language file: languages/YOURLANGUAGECODE/YOURLANGUAGECODE.ini</blockquote>
    Thank you. I have made the translation directly in the code. And it works
    itamturk Friend
    #436600
    I change defauld file but have problem. What can i do ?
    1. jalogin
This topic contains 4 replies, has 3 voices, and was last updated by  itamturk 12 years, 9 months ago.
