  • aushops Friend
    #119157
    Hi All,
    I have followed the instructions to enable Transmenu 2
    I have made the change in index.php option 3
    I’m not sure if there is missing code from my index.php so i have included the code below, would appreciate if someone could check it out for me
    Tony
    Index.php Code
    <?php
    # JA Villadi 1.0 – Mar, 2007
    # Copyright (C) 2004-2007 J.O.O.M Solutions Co., Ltd. All Rights Reserved.
    # @license – Copyrighted Commercial Software
    # Author: J.O.O.M Solutions Co., Ltd
    # Websites: http://www.joomlart.comhttp://www.joomlancers.com
    defined( ‘_VALID_MOS’ ) or die( ‘Restricted access’ );
    $iso = split( ‘=’, _ISO );
    /*echo “<?xml version=”1.0″ encoding=”‘. $iso[1] .'”?’ .’>”;*/
    global $ja_color_themes, $ja_header_images, $ja_width_default, $ja_color_default, $ja_font_size_default, $ja_tool, $ja_menutype, $ja_template_path, $ja_template_absolute_path, $ja_headerimg, $ja_color, $ja_width, $ja_font_size, $ja_template_name;
    $ja_template_name = ‘ja_villadi’;
    # BEGIN: TEMPLATE CONFIGURATIONS ##########
    #support extra color themes
    $ja_color_themes = array(‘default’, ‘orange’, ‘green’); // You can add more color array if needed
    # Change the width of the template
    $ja_width_default = ‘wide’; // ‘narrow’: 800×600; ‘wide’: 1024×768; ‘auto’: fluid width
    # default color
    $ja_color_default = ‘default’; //blank for default, else pick one of in extra color themes $ja_color_themes
    #font size default
    $ja_font_size_default = 3;
    # Enable users option
    $ja_tool = 7; // 0: disable all; 1: Screen tool; 2: font tool; 3: screen + font; 4: color tool; 5: screen + color; 6: font + color; 7: all;
    # Choose your prefer Menu Type
    $ja_menutype = 3; // 1: Split Menu; 2: Son of Suckerfish Dropdown Menu; 3: Transmenu; 4: Script Dropline Menu;
    # END: TEMPLATE CONFIGURATIONS ##########
    # Define the template path ##########
    $ja_template_path = $mosConfig_live_site.’/templates/’.$ja_template_name;
    $ja_template_absolute_path = $mosConfig_absolute_path.’/templates/’.$ja_template_name;
    include ($ja_template_absolute_path.”/ja_templatetools.php”);
    $topnav = “”;
    $subnav = “”;
    if ($ja_menutype == 1) {
    require($ja_template_absolute_path.”/ja_splitmenu.php”);
    $topnav = ja_topNav(‘mainmenu’, array(‘default’));
    $subnav = ja_subNav(‘mainmenu’);
    } else if ($ja_menutype == 4) {
    require($ja_template_absolute_path.”/ja_scriptdlmenu.php”);
    $topnav = $jamenu->menuObj->main;
    $subnav = $jamenu->menuObj->sub;
    # Auto Collapse Divs Functions ##########
    $ja_left = mosCountModules( ‘left’ );
    $ja_right = mosCountModules( ‘right’ );
    if ( $ja_left && $ja_right ) {
    $divid = ”;
    } elseif ( $ja_left ) {
    $divid = ‘-fr’;
    } elseif ( $ja_right ) {
    $divid = ‘-fl’;
    } else {
    $divid = ‘-f’;
    ShannonN Friend
    #215739
    Hi Aushops
    I need a live url to see what’s happening or not happening, when you say its not working, do you have submenus are all th e other types of menu working etc etc , It’s hard for me here to know whats really going on
    Cheers ShannonN
This topic contains 2 replies, has 2 voices, and was last updated by  ShannonN 17 years, 9 months ago.
