  • kaventan Friend
    #117530
    I have a problem in the child item for Horizontal transmenu.
    If you would visit my development site http://www.hyundai-kba.com and click on to the Vehicles menu item, you will see the child item “Accent”. However the item is way too far detached from the parent – hundreds of pixel to the bottom.
    What is the setting that I must tweak to get the child to appear directly beheath my parent?
    Thanks for forumers.
    Hung Dinh Friend
    #211403
    Hi kaventan,
    Transmenu have very cool effect but also lot of problems if you have missed-up markup in the template. JA transmenu need carefull coding and integration.
    Because we very little time so support for free products is unlimited. If you want to use the transmenu free of bugs and well tuned for your templates, I should suggest you use the built-in transmenu which is included in most of our JA Templates, you can see them in action at http://www.joomlart.com/templates_demo.php
This topic contains 2 replies, has 2 voices, and was last updated by  Hung Dinh 18 years, 1 month ago.
