  • amitk Friend
    #180428
    In the Ja Nex Template, I want to have two new sections:
    1. Trending Topics (Topics which are being read the most). Example : http://www.foxnews.com/trending/
    2. Most Watched (Videos which are being watched the most). Example : http://www.ndtv.com/trends
    Is there any plugin with Ja Nex which can be used for this purpose.
    I would rather prefer not to use external plugins, but if in case I might be tended to do so, could you suggest something ?
    Awaiting reply.
    Thanks.
    MoonSailor Friend
    #466224
    We do not have any plugin which can be used for this purpose. If you want ti create two sections similar to url http://www.foxnews.com/trending/, http://www.ndtv.com/trends, you can use content or k2 component and restyle it.
This topic contains 2 replies, has 2 voices, and was last updated by  MoonSailor 12 years, 4 months ago.
