  • ahmetsait Friend
    #127214
    Ajax ist wonderful but it does not work good with the Turkish language.
    The special charakters does not appear in the slider module.
    How can I solve this problem?
    lehoai Friend
    #244308
    Hi ahmetsait,
    I had view your live site and i think no problem there. Can you give me some example?
    ahmetsait Friend
    #244338
    I had switched off the Ajax… So it seems normal.
    Now It is switched on…
    Look at please again,
    In the slider, the first 8 product is normal but the followings does not contain the correct Turkish characters…
    It is releated with the Ajax… Without Ajax option everything is normal… but I need Ajax for high speed of loading.
    What do you recommend?
    http://www.trendkitabevi.ch
This topic contains 3 replies, has 2 voices, and was last updated by  ahmetsait 16 years, 9 months ago.
