  • kingsleyjohnsmith Friend
    #982355
    I just had bookshop and mijo cart installed on my website.
    I am an absolute beginner and need tutorial style help.
    My main goal is to upload product data to my admin.php and then use this data to describe products on the website.
    So, first I need info on putting a product on the website,
    and then linking that product to the fields on a data base, using a primary data field.
    Many thanks,
    KIngsley
    Hi Kingsley,
    If you already install Mijoshop component into your site, you can simply go to Administrator site > Components > Mijoshop > and add product as you wish: http://prntscr.com/d1yi13
    Let me know if you need further helps.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 8 years ago.
