May 10, 2011 at 1:48 am #163795
Here is some corrections I propose for the JA QuickContact module version 1.0.1
I have modified the version I have download http://www.joomlart.com/forums/downloads.php?do=file&id=2272 the 10 Mai 2011.
<blockquote>JA Quick Contact module for Joomla 1.6 (7.6 KB) 1.0.1 02-20-2011</blockquote>
If a new version has been released at the time you are reading this mail, DO NOT USE MY FILE.I have corrected some errors and it seems to be working fine now (including famous Error 404).
You can test it by replacing the two files modified or by installing the module as usual with the file:
13038The corrections are:
- Correct the subject writted by the user (avoid error 404)
- Correct sender name in email (use Name writted by the user)
- Correct display of the input box for the subject writted by the user (Make use of admin field “Email’s subject” on focus/on blur)
- Correct Message by adding the subject writted by the user and moddifying the title by “Default Subject – Subject writted by User” or “Subject writted by User” if “Default Subject” is empty in admin panel. (You can change this to just “Default Subject” by removing the line: $subject .= ” – $email_subject”; )
NOTE: “Default Subject” refers to field “Subject” in admin panel
I hope to have done this propoerly but use it with caution.
If you have problem, you just have to reinstall the original version and eventually delete the folder “your_website_root/modules/mod_jaquickcontact/modYouyouBackup”.
You can also read what modifications I have done.Modifications are commented and Files modified are:
- your_website_root/modules/mod_jaquickcontact/mod_jaquickcontact.php
- your_website_root/modules/mod_jaquickcontact/tmpl/default.php
Hope this helps 🙂
PS: If you don’t want to be redirected on the article “Thank you”, The redirect page (in admin panel) must be set to the “page” #contact-us
Here is the modified files:
<?php
defined('_JEXEC') or die('Restricted access');$mainframe = JFactory::getApplication();
if (!defined ('_MODE_JAQUICKCONTACT_ASSETS_')) {
define ('_MODE_JAQUICKCONTACT_ASSETS_', 1);
JHTML::stylesheet('modules/'.$module->module.'/assets/css/style.css');if (is_file(JPATH_SITE.DS.'templates'.DS.$mainframe->getTemplate().DS.'css'.DS.$module->module.".css"))
JHTML::stylesheet('templates/'.$mainframe->getTemplate().'/css/'.$module->module.".css");JHTML::_('behavior.mootools');
JHTML::_('behavior.tooltip');
}$do_submit = isset($_POST['do_submit'])?$_POST['do_submit']:0;
$status =null;$captcha = JPluginHelper::importPlugin('content','captcha');
$user = JFactory::getUser();
$name = isset($user->username)?$user->username:'';
$email = isset($user->email)?$user->email:'';
$text ='';
$subject = $params->get('subject');/*-- Youyou Modification (add) --*/
$email_subject='';
/*-- // Youyou Modification --*/
$senderlabel =$params->get('sender_label',JText::_( 'ENTER_YOUR_NAME' ));
$email_label =$params->get('email_label',JText::_( 'EMAIL_ADDRESS' ));
$subject_label =$params->get('subject_label',JText::_( 'ENTER_YOUR_SUBJECT') );
$message_label =$params->get('message_label',JText::_( 'ENTER_YOUR_MESSAGE' ));
$error = array();
if($do_submit)
$name = stripslashes(JRequest::getVar('name',$name));
$email = stripslashes(JRequest::getVar('email',$email));/*-- Youyou Modification --*/
/* $subject = stripslashes(JRequest::getVar('subject',$subject)); */
$email_subject = stripslashes(JRequest::getVar('email_subject',$email_subject));
$text = JRequest::getString('text');
if(!eregi("^([_a-z0-9-]+)(.[_a-z0-9-]+)*@(+)(.+)*(.{2,4})$", $email) )
$error['email'] = JText::_("EMAIL_REQUIRE");
if(!$name)
$error['name']= JText::_("NAME_REQUIRE");
}/*-- Youyou Modification --*/
/* if(!$subject)
$error['subject']= JText::_("SUBJECT_REQUIRE");
} */if(!$email_subject)
$error['email_subject']= JText::_("SUBJECT_REQUIRE");
}/*-- // Youyou Modification --*/
if (strlen($text)>$params->get('max_chars',1000) ||strlen($text)<5)
$error['text'] =JText::_('MESSAGE_REQUIRE');
if ($captcha==true)
$ccheck = $mainframe->triggerEvent('onValidateForm');if (!$ccheck ||(isset($ccheck)&&!$ccheck[0]))
$error['captcha_code'] = JText::_('CAPTCHA_REQUIRE');
if(count($error)==0)
{/*-- Youyou Modification (add) --*/
if($subject=='')
$subject=$email_subject; /* Email Subject of the user */
else
$subject .= " - $email_subject"; /* Fied Subject in the backend of the module + Email Subjexct of the user */
$header = "From: $email";
/* $message = "
Email: $email <br/> "; */$message = "
Email: $email <br/>
Subject: $email_subject <br/> ";/*-- // Youyou Modification --*/
$message .=
"<br/>
$text
$email_copy =(JRequest::getVar('email_copy',0)==1)?1:0;
$adminemail = $mainframe->getCfg( 'mailfrom' );
$recipient =$params->get('recipient',$adminemail);
$mail = JFactory::getMailer();$mail->addRecipient( $recipient );
if ($params->get('show_email_copy',0)&&($email_copy==1))
$mail->addRecipient( $email);
$mail->IsHTML(true);/*-- Youyou Modification --*/
/* $mail->setSender( array( $email, $subject ) ); */
$mail->setSender( array( $email, $name ) );
$mail->setSubject( $subject );
$mail->setBody( $message );$success = $mail->Send();
if($success===true)
$thanks = $params->get('thank_msg','Thank you!') ;
$url_redirect =$params->get('redirect_url','index.php');
return $mainframe->redirect($url_redirect,$thanks);
else
if (strtolower(get_class($success)) == 'jexception')
$status = $success->getMessage();
else $status = JText::_('Error send mail');
unset($_POST["do_submit"]);
unset($do_submit);}
$templatename = $mainframe->getTemplate();
if (file_exists(JPATH_THEMES.DS.$templatename.DS.'css'.DS.'mod_jaquickcontact.css'))
JHTML::stylesheet('templates/'.$mainframe->getTemplate().'/css/'.$module->module.".css");}
require(JModuleHelper::getLayoutPath('mod_jaquickcontact'));- your_website_root/modules/mod_jaquickcontact/tmpl/default.php
<?php
<?php if ($status!=''):?>
alert('<?php echo $status;?>');
</script>
<?php endif;?>
<div id="<?php echo $params->get('class_suffix','')?>ja-form">
<div class="<?php echo $params->get('class_suffix','')?>form-info">
<h3><?php echo $params->get('intro_text','Contact Us')?></h3>
</div>
<form action="#" name="contact" method="post" id="contact" class="form-validate">
<ul class="<?php echo $params->get('class_suffix','')?>form-list">
<li class="<?php echo $params->get('class_suffix','')?>wide clearfix" id="row_name">
<label for="contact_name" class="required">
<?php echo $senderlabel;?>:
</label>
<div class="<?php echo $params->get('class_suffix','')?>input-box">
<div id="error_name" class="<?php echo $params->get('class_suffix','')?>jl_error"><?php if(isset($error['name']))echo $error['name'] ?></div>
<input id="contact_name" type="text" name="name" value="<?php if ($name!='')echo $name; else echo $senderlabel; ?>" maxlength="60" size="40" onblur="if(this.value=='')this.value='<?php echo $senderlabel?>';" onfocus="if(this.value=='<?php echo $senderlabel?>')this.value='';" />
</div>
</li>
<li class="<?php echo $params->get('class_suffix','')?>wide clearfix" id="row_email">
<label id="contact_emailmsg" for="contact_email">
<?php echo $email_label?>:
</label>
<div id="error_email" class="<?php echo $params->get('class_suffix','')?>jl_error"><?php if(isset($error['email']))echo $error['email'] ?></div>
<input class="input-text" id="contact_email" type="text" name="email" value="<?php if ($email!='')echo $email; else echo $email_label; ?>" maxlength="64" size="40" onblur="if(this.value=='')this.value='<?php echo $email_label ?>';" onfocus="if(this.value=='<?php echo $email_label?>')this.value='';" />
<div class="<?php echo $params->get('class_suffix','')?>small"><?php echo JText::_('NOTICE_REQUEST_USER_REAL_EMAIL');?> </div>
</div>
</li><!--Youyou Modification -->
<li class="<?php echo $params->get('class_suffix','')?>wide clearfix" id="row_subject">
<label id="contact_textmsg" class="required" for="contact_subject">
<?php echo $subject_label?>:
</label>
<div id="error_subject" class="<?php echo $params->get('class_suffix','')?>jl_error"><?php if(isset($error['error_subject']))echo $error['error_subject'] ?></div>
<input class="input-text" id="contact_subject" name="subject" value="<?php echo @$subject?>" size="40"/>
</div>
</li>
--><li class="<?php echo $params->get('class_suffix','')?>wide clearfix" id="row_subject">
<label id="contact_subjectmsg" class="required" for="contact_subject">
</label>
<input class="input-text" id="contact_subject" type="text" name="email_subject" size="40"
onblur="if(this.value=='')this.value='<?php echo $subject_label?>';"
onfocus="if(this.value=='<?php echo $subject_label;?>')this.value='';"
value="<?php if($email_subject!='') echo $email_subject; else echo $subject_label;?>"
</div>
</li><!--// Youyou Modification -->
<li class="<?php echo $params->get('class_suffix','')?>wide clearfix" id="row_text">
<label id="contact_textmsg" class="required" for="contact_text">
<?php echo $message_label?>:
</label>
<div id="error_text" class="<?php echo $params->get('class_suffix','')?>jl_error"><?php if(isset($error['error_text']))echo $error['error_text'] ?></div>
<textarea class="textarea" id="contact_text" name="text" rows="10" cols="40" onblur="if(this.value=='')this.value='<?php echo $message_label?>';" onfocus="if(this.value=='<?php echo $message_label;?>')this.value='';"><?php if($text!='') echo $text; else echo $message_label?></textarea>
</div>
</li>
<?php if ($params->get( 'show_email_copy' ,0)) : ?>
<li class="<?php echo $params->get('class_suffix','')?>wide">
<input type="checkbox" name="email_copy" id="contact_email_copy" value="1" />
<label for="contact_email_copy">
<?php echo JText::_( 'SEND_ME_A_COPIED_EMAIL' ); ?>
</label>
</div>
</li>
<?php endif; ?>
<?php if ($captcha):?>
<div id="error_captcha_code" class="<?php echo $params->get('class_suffix','')?>jl_error"><?php if(isset($error['captcha_code']))echo $error['captcha_code'] ?></div>
<?php$mainframe->triggerEvent('onAfterDisplayForm');
</div>
</li>
<?php endif;?>
<li>
<div style="padding-top: 10px;">
<a href="javascript:void(0)" id="ac-submit" class="button-img but-orange"><span class="icon icon-submit"> </span><span><?php echo JText::_("SEND_EMAIL"); ?></span></a>
</div>
</li>
</ul>
<input type="hidden" name="subject" id="subject" value="<?php echo $params->get('subject','Error 404')?>" />
<input type="hidden" name="category" value="Error/Problems using site" />
<input type="hidden" name="do_submit" value="1">
<?php echo JHTML::_( 'form.token' ); ?>
</form>
</div>
/* <!+@(+.)+{2,4}$/;
if(!regex.test(email))
if((email=='')||(email==emailabel))
$('error_email').innerHTML ='<?php echo JText::_('ERROR_EMAIL_EMPTY')?>';
else
$('error_email').innerHTML ="<?php echo JText::_('ERROR_EMAIL_INVALID')?>";
$('row_email').addClass('error');
ck=false;
else
$('error_email').innerHTML ='';
var name = $('contact_name').value;
if((name=='')||(name==senderlabel))
$('error_name').innerHTML ='<?php echo JText::_("ERROR_NAME_INVALID")?>';
$('row_name').addClass('error');
ck = false;
else
$('error_name').innerHTML ='';
}/*--// Youyou Modification --*/
/* var subject = $('contact_subject').value;
if(subject=='') */var email_subject = $('contact_subject').value;
if(email_subject=='' || email_subject=='<?php echo $subject_label?>')/*--// Youyou Modification --*/
$('error_subject').innerHTML ="<?php echo JText::_("SUBJECT_REQUIRE")?>";
$('row_subject').addClass('error');
ck = false;
else
$('error_subject').innerHTML ='';
var message = $('contact_text').value;
if((message.length>maxchars) ||(message.length<5)||(message==messagelabel))
{$('error_text').innerHTML ='<?php $error_message = JText::_('ERROR_MESSAGE_INVALID'); echo addslashes($error_message);?>';
$('row_text').addClass('error');
ck = false;
else
$('error_text').innerHTML ='';
if(captcha)
var captcha_code = $('captcha_code').value;
if((captcha_code=='')||(captcha_code=='Type the code shown'))
$('error_captcha_code').innerHTML = "<?php echo JText::_('EMPTY_CAPTCHA')?>";
ck = false;
else $('error_captcha_code').innerHTML = "";
if(ck)
$("contact").submit();
return ck;
</script>
This topic contains 1 reply, has 1 voice, and was last updated by youyou 13 years, 9 months ago.
