moyousuf Friend
moyousuf
- December 2011
- 3 times in 1 posts
February 29, 2012 at 2:57 am #174419Hi,
Twitter Plugin extends beyond body and it looks awkwardly as in attached picture, How can we solve it please?Thanks.
himangi Friend
himangi
- April 2011
- 345 times in 332 posts
February 29, 2012 at 6:11 am #440798It seems to me that the column width is lesser than the button width.. Have you tried increasing column width or using different button?
moyousuf Friend
moyousuf
- December 2011
February 29, 2012 at 7:31 am #440811Thanks for your answer.
can you tell me how can i increase column width of that particular column please?, if you tell me CSS path and that particular CSS it would be great.Or Can we change the button please? what is the way to change to button?
thanks in advance.
himangi Friend
himangi
- April 2011
February 29, 2012 at 9:48 am #440829Hi,
To increase the column width in JAT3 template, you need to follow the steps below..
- Go to Extensions > Template Manager > JA Community Plus > Layouts Tab
- Considering you are using Default layout, click on the Edit link in front of it and find code similar to the following
- In the code above colwidth=”21.5″ specifies the width of columns in the template. It is in percentage.. Increase the value instead of 21.5 and you will see the difference..
<blockquote><blocks name=”middle” colwidth=”21.5″>
<block name=”right-mass-top”>right-mass-top</block>
<block name=”content-top”>content-top</block>
<block name=”content-bottom”>content-bot</block>
<block name=”right1″ style=”jarounded”>left</block>
<block name=”right2″>right</block>
</blocks></blockquote>If you are using JA Twitter module then you get couple of button options in Button Settings > Button type is chosen as Simple.
himangi 12 years, 11 months ago.
Twitter plugin extends outside Body , how can we keep it within?
