  • kmikol Friend
    #150924
    I have two problem with Ja Rasite template:
    With Firefox the site is visible in RTL by default.
    I have a problem to enter in the admin section, password not exact. How can I reset it?
    jay973 Friend
    #342925
    I don’t know about the RTL problem as I never use it but a great guide can be found here to resetting your password. It only takes a few minutes.
    Hope this helps.
    Cheers,
    Jason.
    kmikol Friend
    #343036
    I made a site in local with Ja Rasite template and if I view it with IE 8 all is very good in ltr direction, but if I view the site with Firefox 3.6 I view it in rtl direction.
    It is possible to deactivate the language direction and to have only the ltr?
    cansay Friend
    #343053
    <em>@kmikol 177874 wrote:</em><blockquote>I made a site in local with Ja Rasite template and if I view it with IE 8 all is very good in ltr direction, but if I view the site with Firefox 3.6 I view it in rtl direction.
    It is possible to deactivate the language direction and to have only the ltr?</blockquote>
    I had this problem to.
    I think it migth be browser cach in Firefox for you m8?
    try and clear it ?
    kmikol Friend
    #343060
    I have deleted the cache but the problem is present too!
    The only view with Firefox is in RTL mode, if I select LTR mode when I click on any link the mode go automatically in RTL mode.
    This is a serius problem that I have only with the Ja Rasite templates, with any other template there is not this problem.
    😮 Please help me!!!!! 😮
    Dear kmikol!
    1) Here is the solution to resolve a problem with administrator’s password
    http://forum.joomla.org/viewtopic.php?t=10985
    2) please check browser: does the browser disable cookie?, you try to test this site on other browser?
This topic contains 6 replies, has 4 voices, and was last updated by  Saguaros 14 years, 6 months ago.
