  • hbenachou Friend
    #200203
    I am using the typo in JA University template by adding the class names to the appropriate tags, but the results aren’t good : it doesn’t look like the template.
    I’ve been reading other posts from people that had (about) the same problem, so I know people went through that but no one bothered to actually detail a solution to the problem in their threads.
    please help!
    Could you explain in details where are you encountering problems ?
    typo works in this way , css code is loaded through template.css file so if you are adding a particular css class in your content or module suffix that class should be declared before somewhere, if not then template.css should be double checked to verify why it doesn’t works.
    hbenachou Friend
    #544288
    hmmm.
    yes let me check template.css and get back with you.
    thanks for the fast reply tho. 🙂
    hbenachou Friend
    #544290
    yep! as you suspected the ja-typo-box isn’t declared in the template.css
    cool we found the problem. now how do I fix it?
    I need a template.css where all the JA University classes are already declared. That would be ideal.
    hbenachou Friend
    #544293
    actually, it seems that those particular declarations are on another css file : typo.css. how do I get my page to use this css?
    <em>@hbenachou 439235 wrote:</em><blockquote>actually, it seems that those particular declarations are on another css file : typo.css. how do I get my page to use this css?</blockquote>
    You can download the quickstart version of the template , extract it and take the template.css from there and compare with your file to verify what is missing
    hbenachou Friend
    #544345
    Yes! I just downloaded the quickstart and tried to compare the template.css file to the one I have. They are identical. :((
    the issue is really this “ja-typo-box box-information”: it is just nowhere to be found on template.css,
    on the other hand it does exist on the file typo.css but it seems that typo.css isn’t used.
    suggestions? please?:((
    <blockquote>on the other hand it does exist on the file typo.css</blockquote>
    On your website is installed Ja University T3 version – so i think you are checking the wrong files
    Here you can find the documentation for your template version
    Here you can find the typography page of your template
    hbenachou Friend
    #544354
    Yes! you were right I was checking the wrong files, the wrong version the wrong planet :D! But! there is a solution to reconcile both worlds.
    So I took the declarations that are interesting to me and pasted them to the template.css that I use and magically it somewhat worked.
    So here is what I needed :
    /* MESSAGE BOXES AND LEGENDS STYLE
    /* Box style —*/
    p.ja-typo-box {
    border: 1px solid #ddd
    padding: 10px 10px 10px 50px;
    text-shadow: 1px 1px 0 rgba(255,255,255, .5);
    /* Box with icons */
    p.box-download, p.box-sticky, p.box-confirmation, p.box-error, p.box-warning, p.box-information, p.box-system {
    background-repeat: no-repeat;
    background-position: 10px 15px;
    p.box-confirmation {
    background-color: #e4f2d4
    background-image: url(../images/icons/message/icon-tick.png);
    border-color: #b8d199
    color: #4e8904
    p.box-error {
    background-color: #f2dbd4
    background-image: url(../images/icons/message/icon-error.png);
    border-color: #f6a992
    color: #be4b22
    p.box-warning {
    background-color: #fbebc1
    background-image: url(../images/icons/message/icon-warning.png);
    border-color: #e1bc88
    color: #ca7326
    p.box-information {
    background-color: #d4e6f2
    background-image: url(../images/icons/message/icon-information.png);
    border-color: #98c1de
    color: #1e81af
    p.box-download {
    background-image: url(../images/icons/message/icon-download.png);
    p.box-sticky {
    background-color: #ffffcc
    background-image: url(../images/icons/message/icon-sticky.png);
    p.box-system {
    background-color: #ccd4fa
    background-image: url(../images/icons/message/icon-system.png);
    border-color: #a4b1ed
    color: #626ccb
    I pasted this code in template.css and now I can use the classes easily.
    Thanks a bunch for your help moderators, Being pointed to the right direction is priceless 🙂
    hbenachou Friend
    #544355
    /* Box style —*/
    p.ja-typo-box {
    color: #4e8904
    p.box-error {
    color: #be4b22
    p.box-warning {
    color: #ca7326
    p.box-information {
    color: #1e81af
    p.box-download {
    p.box-sticky {
    p.box-system {
    color: #626ccb
This topic contains 10 replies, has 2 voices, and was last updated by  hbenachou 10 years, 3 months ago.
