Viewing 15 posts - 1 through 15 (of 37 total)
  • qbali JATC
    #169767
    any solution for this ?
    khoand Friend
    #419857
    What problem do you have? Could you explain more?
    qbali JATC
    #419862
    i have put some code of typographi but i does not work, i check the typo plugin in plugin manager but is not there, how can i find typo plugin to active it ? where i can get typo plugin ?
    khoand Friend
    #419867
    lucija Friend
    #420087
    Yes, but with license like this: JATC Standard Membership – 1 year you can’t access to dowload this plugin…?
    Do I have to pay more licensing to download this or am I wrong? I mean this is not right, when I bought the template it said that I’ve purchased everything that comes with the template, but the main thing is not included, the typography?
    I don’t understand?
    Best regards!
    khoand Friend
    #420092
    Yes, you do. Because typography plugin is belong JATC.
    I don’t understand?
    It means that when you down any templates of joomlart, you can download modules and plugins that the template needs.
    lucija Friend
    #420178
    I did it, from another link to the typo download worked.
    But still the h3 paragraph style looks black and with font different from the picture below:
    how to obtain the same look like the title: “Island of Thera, Greece” in the picture attached?
    Probably this isn’t a h3 style, are there some other styles, is there any tutorial about this?
    Is Ja Comment included in the template Ja Travel or I have to buy it separately? In the template showcase it is shown, so I tought it will be included but I didn’T get it in the quickstart package.
    When I enable module jaclatest_comments to show the comments they are not shown properly…
    Manny thanks
    regards
    lucija
    1. pict1
    khoand Friend
    #420256
    Could you give me a link to your website?
    I have to buy it separately. Because, you just download modules and plugins that template needs (not component)
    lucija Friend
    #420259
    http://www.bol-apartments-sarbunal.com
    Sorry, I wrote wrong, when I turn on mod_k2_comments modul (not jaclatest_comments ) to show the comments from articles in K2 Items and when I click on the comment it looks strange.
    Module jaclatest_comments doesn’t show nothing, perhaps because I haven’t Ja Comment component installed?
    khoand Friend
    #420614
    I don’t see h3 tag. But you want to have effect like demo, you put your text into
    <div class="view-cotent"><h4>your text</h4></div>
    lucija Friend
    #420716
    Thank you but it doesn’t work still, look at the link:
    http://bol-apartments-sarbunal.com/index.php?option=com_content&view=article&id=76&Itemid=91
    The title “Plaža Soline Vrboska” should be looking like that…
    lucija
    bhto Friend
    #420764
    Slabo ovi pomazu Lucija, uzmu pare i daju nekoj djeci da se snama zezaju nazalost. Inace dobar ti je web, naravno da se jos uredi biti ce super.
    khoand Friend
    #420774
    You try another way. You add this code into /templates/ja_travel/css/template.css
    h2{
    color: #EF761A !important;
    font-size: 125%;
    font-weight: normal;}
    lucija Friend
    #420779
    Misliš da nas zezaju? I meni se čini. Reci šta bi ti još uredio na mom webu? Imaš i ti web na joomli? koji ti je?
    bhto Friend
    #420784
    poslao sam ti PM
This topic contains 37 replies, has 4 voices, and was last updated by  khoand 13 years, 1 month ago.
