Viewing 15 posts - 16 through 30 (of 37 total)
  • khoand Friend
    #420898
    You use English language, please
    lucija Friend
    #420902
    yes, sorry
    I’ve put a code like this and It’s ok now:
    <h2>
    <p class=”text-color”>Plaža Soline Vrboska</p>
    </h2>
    But comments modul mod_k2_comments doesn’t work, when I click to see the comments this is wat it comes out:
    http://bol-apartments-sarbunal.com/index.php?option=com_k2&view=item&id=20:apartman-a4+2#comment11
    The comments are on every page under the name “Vaši dojmovi” (look at the picture):
    Do you know how to solve this?
    thanks
    1. pic3
    khoand Friend
    #421787
    <em>@lucija 277854 wrote:</em><blockquote>yes, sorry
    <h2>
    </h2>
    thanks</blockquote>
    You can try to disable cache or cache optimize css/js to No. If this issue isn’t solved, could you give me user admin & ftp account, please?
    lucija Friend
    #421827
    Could you tell me where or how exactly to do this: disable cache or cache optimize css/js to No ?
    thank you!
    khoand Friend
    #421830
    You login backend > Extensions > template manager > ja_travel > Global tab > set Cache Mode is Disabled, Optimize CSS is No
    lucija Friend
    #421833
    When I do this I receive this message when I cklick Apply: “An error has occured when saving Global Settings… Array”
    lucija Friend
    #421834
    Now I changed also Optimize JS to “No” and now it let me to save the changes but nothing happened on the Frontend:((
    khoand Friend
    #421835
    It’s strange. Could you give me username+password of your backend and ftp? I will check it.
    lucija Friend
    #421866
    I’ve sent you a private message
    khoand Friend
    #422737
    Please turn K2 Jcomments plugins off. It made this error.
    lucija Friend
    #422741
    Thank you, now it looks ok. The issue is solved, but now for a few days I receive comments about viagra, look at the picture… what to do?
    thank you!
    1. dojmovi_viagra
    khoand Friend
    #422743
    Maybe, my partner tried to test your page. Now, it’s ok.
    lucija Friend
    #422747
    it’s ok because I’ve manually deleted it, but I receive every day 10 comments like this…
    khoand Friend
    #422752
    If it’s so, it doesn’t relate with my partner. It’s advertising (spam). I think it’s not a bug. You can use capcha to reduce spam when using comment function.
    lucija Friend
    #422753
    ok could you tell me how to use that?
This topic contains 37 replies, has 4 voices, and was last updated by  khoand 13 years, 1 month ago.
