  • jemir Friend
    #199655
    Hi, i already install JA Typo System Plugin and JA Typobutton Plugin. But it not display as it should. Background color for message box is not appear. Please help
    1. hawkstore
    Nazario A Friend
    #542386
    @jemir,
    After you have installed JA Typo System Plugin and JA Typobutton Plugin, you should see the JA Typo button in the article manager. It helps you style your article to show on front-end.
    Also, when you add HTML code to content – article, please make sure you turn the Editor off. Go to Sytem >> Global confoguration, select Editor – None in the field Default editor.
    You can refer at this documentation.
    1. Screenshot_47
    2. Screenshot_48
This topic contains 2 replies, has 2 voices, and was last updated by  Nazario A 10 years, 6 months ago.
