  • bozidar Friend
    #123153
    I am building the Site, and everything works well except all links are underlined at left and right position. I put there some images, but they are underlined. I try to put them like banners… but the same problems appears. Then I put them into the content, and publish them there… the same problem.
    Please, look at yourself: http://85.94.76.38/~automani/
    You can see three images in the right column – Stanje u prometu, Prometne nesrece, Vremenska prognoza (it’s Croatian, but never mind in this case).
    How can I fix this? How can I move these underlines out?
    Thank you.
    Sinisa
    cssyeah Moderator
    #230873
    Hi Bozidar,
    Open the template_css.css file and add this CSS code section into the template_css.css file.
    #ja-col1 a,
    #ja-col2 a {
    border-bottom: none;
    :d
    bozidar Friend
    #230930
    Thanks Trungch.
    It works 😉
This topic contains 3 replies, has 2 voices, and was last updated by  bozidar 17 years, 2 months ago.
