fiumeciane Friend
fiumeciane
- June 2009
- 6 times in 1 posts
August 1, 2011 at 3:21 am #166914[FONT=”Georgia”]Hi, I have the same problem described in this thread. I tried to modify the file as described in this reply (folder mod_janews not mod_janews2), but the problem remains.
Help me please.[/FONT]
Sherlock FriendSherlock
- 2478 times in 2162 posts
August 6, 2011 at 10:39 am #404766hi fiumeciane,
I just checked your site in IE8 And did not see the problem, Do you mind attach a screenshot ?
August 6, 2011 at 5:09 pm #404797Hi Dat,
I upgrade template and modules
The problem is IE 8 on http://medinapoli.it/
Can you help me ?
TELINE IV Joomla 1.5.23
fiumeciane Friendfiumeciane
- June 2009
August 6, 2011 at 5:34 pm #404799Hello Dat, now you do not see the problem because I set in the JA News Frontpage Module> Theme settings> Effect, “Move fade.” If I set “Horizontal Move” obtaining the same problem you see here. Identic.. As you can see are not the only one that I have this problem.
August 6, 2011 at 6:15 pm #404802The problem is in the JA News Frontpage Module con Explorer 8 – Jommla 1.5.23
I tried to turn the other modules.Please help me. Thk
August 8, 2011 at 2:37 am #404855<em>@fiumeciane 257943 wrote:</em><blockquote>Hello Dat, now you do not see the problem because I set in the JA News Frontpage Module> Theme settings> Effect, “Move fade.” If I set “Horizontal Move” obtaining the same problem you see here. Identic.. As you can see are not the only one that I have this problem.</blockquote>
Hi fiumeciane,
I went to your back-end, change Effect to Move hoziontal but still did not see the problem in the IE8, Kindly check again the problem.
- June 2009
August 8, 2011 at 5:35 am #404878[FONT=”Georgia”]What? This is what appears to me (clean cache IE8).[/FONT]
[FONT=”Georgia”]After 1 minute[/FONT]
[FONT=”Georgia”]After 3 minutes[/FONT]
[FONT=”Georgia”]After 5 minutes[/FONT]
[FONT=”Georgia”]After this test I set mode “fade” again…..[/FONT]
[FONT=”Georgia”]Teline IV demo has the same problem after 5 minutes[/FONT]
August 10, 2011 at 9:32 am #405350hi fiumeciane,
Are you running the Windown 64 bit ?
I have reported this problem to our developers for a checking and fix it then, You can track the issue in here
http://pm.joomlart.com/browse/JAECMODJANEWSFP-42To know when it is fixed !
- June 2009
August 10, 2011 at 1:48 pm #405411Hi Dat,
No, i use Windows XP SP3 32 bit.AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 3 voices, and was last updated by fiumeciane 13 years, 3 months ago.
Unresolved problem with IE8. Help me please
