February 2, 2016 at 6:24 am #874093
unwanted small space 1.below slideshow and 2.below Testimonials block why so?how to remove??refer attachement
kindly help to remove & reply quick-
Pankaj Sharma Moderator
February 3, 2016 at 3:11 am #875022Hi
There is no unwanted space in the module , its template design you can change the padding
go to
/2016/templates/ja_platon/local/acm/container-tabs/css/themes/indigo/style.css
find this code.acm-container-tabs .tab-pane .section-inner { padding: 72px 0 0; }
decrease the value of the 72px as per needs .
Testimonials module looks normal at my end like in demo site there is no issue , it use normal padding space .
Viewing 2 posts - 1 through 2 (of 2 total)This topic contains 1 reply, has 2 voices, and was last updated by Pankaj Sharma 8 years, 10 months ago.
