aldyf Friend
aldyf
June 7, 2015 at 12:34 pm #207060Dear JA Developer
I have a problem with the appearance of upcoming events module. the font in date is to big like on screenshot.
Please help me?
Thank you very much.
June 7, 2015 at 1:08 pm #573180Hi
Evidently original settings are overrided by some other css customization
Since your website is in localhost so cannot be verified directly , i can suggest to restore original css file for events Ja Acm module
You can extract on your local the quickstart zip file and restore the /acm/events/css/style.css file
aldyf Friendaldyf
June 7, 2015 at 1:16 pm #573181Hello pavit.
Thank you very much for the reply.
I have restored the original style.css, but it doesnt work.
This is my website http://beta.menaranews.com
How can i fix this?
pavit Moderatorpavit
June 7, 2015 at 1:32 pm #573182Hi
Please send me via Private Message a temp super user account for your backend, i will try to take a look at it
aldyf Friendaldyf
aldyf Friendaldyf
June 8, 2015 at 12:45 pm #573302Hi pavit
Yes, it is solved
Thank you very much
aldyf Friendaldyf
June 8, 2015 at 12:45 pm #738330Hi pavit
Yes, it is solved
Thank you very much
aldyf Friendaldyf
June 8, 2015 at 12:46 pm #573303Hi pavit
Yes, it is solved
Thank you very much
aldyf Friendaldyf
June 8, 2015 at 12:46 pm #738331Hi pavit
Yes, it is solved
Thank you very much
Viewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 2 voices, and was last updated by aldyf 9 years, 6 months ago.
