  • Khanh Le Moderator
    #124269
    We’ve just made an update for Genista template to fix the problem of transparency and link on IE6. Changes are only made on 2 files: ja_vars.php and ja_templatetools.php. If you get problem on IE6, please update these 2 files.
    ferrioluk Friend
    #234289
    Hi khan lee,
    Where can i download this two updated files? I go to the download files..but it says, these files were posted on the 3rd of november, so i guess new versions are not yet uploaded.
    Khanh Le Moderator
    #234348
    I updated file directly by ftp, therefore the file date in database is no change. 🙂
    ferrioluk Friend
    #234367
    Thanks very much! Great!
    cwigg Friend
    #234618
    Is this supposed to be fixing an issue where links become not linkable in IE6 ?
    orpheus2510 Friend
    #234857
    The bugfix is not satisfying, because it works with the standard Joomla elements, but not with extensions. There you still have the IE6-problem. My pictures in Ponygallery e.g. are still not clickable.
    cwigg Friend
    #234858
    it wasnt fixing any links for me. but I worked out this fix:
    the problem is fixed by adding
    position: relative;
    to lines 68 (normal link) and 171 (.inputbox) in template_css.css
    thre may be other elements that need the position relative attribute.
    orpheus2510 Friend
    #234866
    There must be a solution in the template’s css only. As long as there is non, I can’t use it on my site.
    ferrioluk Friend
    #234872
    Same applies to my site. More than 50% of visitors use ie 6.0 and this is a big downfall. We´ve been waiting quite a long time now for a fix, it seems to come and then something fails again…a bit disapointing.
    It´s been already nearly a month. And it is time to start thinking of using another template, not as nice, but that will do the job, which is the most important thing.
    cwigg Friend
    #234874
    Although I have fixed my own site, to my own satisfaction, it would appear as if the JA team again have no interest in even recognising that there is a problem here for many other customers of JA.
    formad Friend
    #235047
    Hello, is there already an solution for the dissapering backgroud in Internet eplorer 6. Kind regards matthijs
    Derek Buntin Friend
    #235162
    Hi Guys,
    Any further forward on this, it seems only to work on page refresh, so why is that?
    Kind Regards
    Derek Buntin
    Perfect Designing Limited
    vladimirjaros Friend
    #237070
    This is the solution … thanks
    yavuzturk Friend
    #239011
    we have an error when we changed ja_genista_xmas folder ?
This topic contains 14 replies, has 8 voices, and was last updated by  yavuzturk 16 years, 10 months ago.
