  • 01920 Friend
    #168419
    Hallo,
    I have upgraded my site to 1.7; I have installed the “Extension Manager”, and after that I have upgraded my JA purity II site. It works now, but the extension manager still reports “version 1.0.0 beta”. If I click on “upgrade now” (Joomlart updates), the only result is the write “processing – please wait”.
    Where am I wrong?
    Thank you! 
    Manos Moderator
    #417511
    Can you provide us with a temp admin and ftp access so we can see this issue and provide with the proper solution ?
    Manos
    barentsforlag Friend
    #417552
    I have the same problem. I updated my joomla from 1.6.5 to 1.7 and now I try to update my Ja Teline III v2 template. After clicking on “Upgrade now” I just see “Processing. Please wait…”, nothing else happens. I tried it several times. Please help me!
    Olga
    Manos Moderator
    #417570
    Hi Olga,
    Can you please show us your website ? and perhaps some temp admin and ftp access will be more helpful to identify your sites problem.
    Manos
    Manos Moderator
    #417579
    Hi Olga, i have seen your site and i can tell that this is permition error so i can only suggest that!
    Make a local copy ( if you are using localhost for development it’s easy ) of your site and try to upgrade on your localhost everything on your site.
    Otherwise you could change mode of the file params.ini and try to do the upgrade on your server, but please never forget to create a backup first!
    Manos
    #417729
    Hi Manos,
    I will try this. Thank you!
    Olga
    Manos Moderator
    #417745
    <em>@01920 266879 wrote:</em><blockquote>Hallo,
    Where am I wrong?
    Thank you! </blockquote>
    This is a permission issue, i suggest that you create a full backup of your site ( files and db ) and then set permissions to folder /ja_purity_ii to 777 and try to upgrade again ( it’s better to try that on localhost )
    #418259
    Hi Manos,
    I changed the mode of params.ini, now the upgrade was successful 🙂 ! Thank you very much!!!
    Olga
    Manos Moderator
    #418290
    Hi Olga
    Thanks for the update!!! I am glad that your issue is solved!
This topic contains 9 replies, has 3 voices, and was last updated by  Manos 13 years, 2 months ago.
