  • kaimano Friend
    #187188
    Upgrade to T3 1.2.4 via JoomlArt Extensions Manager brake Ja-mero backend template, see images….
    T3 plugin is enabled, off course.
    Any idea?
    Marco.
    1. JA_Extension_Manager
    2. JA-MERO_Backend
    HeR0 Friend
    #491609
    Dear Marco,
    Did you upgrade JA Mero template? If you still are facing this issue. Please uninstall T3 plugin and re-install latest T3 plugin version.
    kaimano Friend
    #491701
    Hi HeR0,
    yes, I have upgraded ja-mero to 1.0.3. I tried to uninstall T3 and re-install latest version, but did not seem to work.
    phong nam Friend
    #491774
    Hi kaimano,
    Would you mind sending me a PM with your admin account for checking this issue ?
    Leo
    kaimano Friend
    #491826
    Thanks Leo,
    I sent you a PM with the login credentials
    kaimano Friend
    #491928
    Thanks Leo,
    I saw that you solved the problem with the upgrade.
    I would like to know how.
    I need to replicate it on the production site
    Ciao
    phong nam Friend
    #491929
    Hi Kaimano,
    Indeed, my teammate (@Wall Crusher) helped to fix that issue on your website. Here is what he did:
    Open<blockquote> pluginssystemt3includescoreadmin.php </blockquote>, replace
    $body = preg_replace('@<forms[^>]*name="adminForm"[^>]*>([w|W]*)</form>@msu', $buffer, $body);
    with
    $body = preg_replace('@<forms[^>]*name="adminForm"[^>]*>(.*)</form>@msU', $buffer, $body);
    Leo
    kaimano Friend
    #492012
    Many Many Thanks!
    All work properly now.
This topic contains 8 replies, has 3 voices, and was last updated by  kaimano 11 years, 6 months ago.
