  • salvomic Friend
    #662000
    hi,
    I upgraded recently from Teline IV to Teline V and configured it in Joomla 3.4.3).
    I was using some plugins like JA Social, JA Thumbnail, JA Popup, JA News…
    Now I configured two JACM modules to show news (Magazine featured and normal), they works but images aren’t loaded (I already set “media/jatc” as path in Article configuration (shared option)…
    JA Popup and JA News uses /images/resized to resize images.
    Sometimes images wrongly resized appear on JACM but they are cut vertically…
    I need to use JA Popup (and thumbail) to get images in article gathered and clickable with effects.
    Shortly: image resize into media/jact does”t work: no folder big, medium, small are there, no thumbnail and images in the two modules…
    See attached image.
    Another problem is with Social (“Share this”): I put the AddThis code in the “before head” section of “Custom code” of the Template, but no icon is showed into article.
    Any help, please?
    Thank you in advance!
    Salvo
    salvomic Friend
    #662054
    thank to pavit that solved the image problem (see here) for me!
    I need solve the social issue…
    salvomic Friend
    #745547
    timtecsa Friend
    #662055
    I use j2xml Set Images plugin to load image links to Images and Links tab automatically on article Save. Useful if importing from a previous site where you haven’t used that image method.
    http://extensions.joomla.org/extensions/extension/migration-a-conversion/data-import-a-export/j2xml-set-images
    timtecsa Friend
    #745548
    salvomic Friend
    #662056
    hi,
    very interesting, thank you!
    I’m downloading the plugin.
    salvomic Friend
    #745549
    hi,
    timtecsa Friend
    #662220
    The J2XML Grab Images plugin I find very useful too. Teline IV and V modules are most unhappy if images are not stored locally. http://extensions.joomla.org/extensions/extension/migration-a-conversion/data-import-a-export/j2xml-grab-images
    timtecsa Friend
    #745563
This topic contains 9 replies, has 2 voices, and was last updated by  timtecsa 9 years, 4 months ago.
