  • genejimenez Friend
    #1026533
    Upgraded to Builder Pro and the LIVE site editor or site does not load. BEYOND frustrated, as is my client. Please advise.
    Pankaj Sharma Moderator
    #1026644
    Kindly take backup off site and update the JA Builder to latest version 1.0.3
    http://prntscr.com/ewz5bb
    After update clear browser cache and check.We have fixed many bugs in the latest release.
    Let me know if you still got issue after update.
    genejimenez Friend
    #1026989
    It still DOES NOT WORK. Updated to current version. It will not load to edit, nor present site as it should be. Please help.
    #1027037
    I checked your site and there is no block added for the Home page: http://prntscr.com/exo7jb
    Nothing in the Revision.Can u add some blocks and try to publish the page.
    In JA Builder there is a page Foundation to Drive but it does not associate to any Menu so its not showing.
    I just created a test page for you and imported the Foundation to drive data file on it.
    Kindly check it now.
    Test page: http://prntscr.com/exo9an
    Let me know if you face any issue in the page or how to show content.
    genejimenez Friend
    #1028301
    Thank you. By the way, it doesn’t work in Safari. Chrome it does work. Thank you kindly.
    #1028354
    Kindly clear browser cache and cookies, login on JA Builder and site again and check the blocks.
    It will work.
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 8 months ago.
